Should my friend buy
Discussion in 'Gen 3 Prius Main Forum' started by cuongdyna, Oct 22, 2015.
  1. cuongdyna
    cuongdyna Junior Member
    49
    So Cal
    She lives in Los Angeles County 12k miles a year is chump change...haha
    #21 cuongdyna, Oct 28, 2015
    52,863
    get a new one then, for 20k.(y)
    52,863
    ouch, i only drive 10k a year.:cool:
  4. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    I logged 5463 miles over the last year.
  5. B. Roberts
    B. Roberts Hypah Milah! Ayuh.
    691
    212
    used to be "Glacial" Maine and now FL
    You take a chance of sorts with any used car you buy. And you still take a chance with a new one. I wouldn't have much fear of owning a second Gen Prius with average yearly mileage, unless the car was only driven in Death Valley or Phoenix. Extreme heat is not a friend of batteries.
    If your friend is that worried about battery life, go for a Corolla. Can still get good MPG with a car that has demonstrated longevity and reliability, just like well maintained Prius have.
  6. JC91006
    16,936
    8,647
    I have a 2006 model that's just over 150k miles. They seem to be quite reliable but I did have to do some work on the car. Here is the list I've done to my 2006.
    1. water pump leaked (at around 117k)
    2. rear shocks leaked (at around 117k)
    3. engine makes ticking sounds (still going on at 150k)
    4. HV battery replaced under warranty at (149k)
    5. Catalytic converter just failed at (153k), no longer under warranty
    6. Engine burns oil at about 1 quart every 1500 miles average.
    Other than that, the car runs pretty good. The problems I listed are pretty common for Prius cars with 150k miles (not the ticking engine). Any one of those issues can creep up on you
  7. B. Roberts
    691
    212
    Our 2005 had 145,000 miles on it when we traded for the 2011. No oil consumption, no leaks. Only problem we had with it was eating rear tires at a faster rate than normal through it's life with us. Not typical for us, since we drive fairly gently and have always gotten maximum miles from tires. Toyota service and alignment shops could not find the problem. Other than that, it was in excellent shape. It did commuter service and quite a few long trips.
