Should the mechanic have caught this? (possible ABS issue)
Discussion in 'Newbie Forum' started by emchelle, May 17, 2018.
  1. emchelle
    emchelle New Member
    Austin, TX
    Three Touring
    Just bought a 2008 Prius Touring, 109k miles. Previous owner had babied it and faithfully changed oil, rotated tires, etc. all at his local Toyota dealership.
    I still took it to a highly-rated (as in, honest and experienced) Hybrid repair shop for a good 2-hour buyer's check before purchasing it from the dealer (who is himself honest and highly-rated, but less experienced with Hybrids). I'm coming off 3 years of driving an entirely electric car, so I really wanted to have a more experienced eye look the car over thoroughly.
    They pointed out a couple minor issues - passenger head lamp needs to be replaced, for instance - but they said the car looks great. I grilled them just to be sure, and they do guarantee their own work for 48 months.
    So, I figure, I'm as good as I can reasonably be.
    That was two days ago. I bought the car. This morning, the ABS starting lighting up and beeping and (while I didn't note any serious braking issues), it was immediately concerning.
    Called Toyota: despite their customer going to see them twice per year at a bare minimum, because he didn't have any problems with the actuator then the actuator was NOT a problem. They never replaced it. Extended warranty expired 3 weeks ago.
    I'm not 100% sure that's what is going on but I am thinking it might be the case. The Hybrid shop doesn't open for an hour, and I'm not intending to be rude or to point the blame at them, but just so I know: is that something they should have caught, a mere two days before the problem cropped up? Or do those actuators just die without any warning?
  2. emchelle
    emchelle New Member
    Austin, TX
    Three Touring
    UPDATE: Just talked with the mechanic, and he doesn't think it's the actuator at all (he was very familiar with that issue). He agreed that's something you'd certainly hear running when the engine was on.
    They had noted codes C1241 & C1378, but also that the 12V battery looked new and the codes could have been related to that. Since they have come back they'll need to do more thorough diagnostics. I'll be taking the car back to them on Monday.
  3. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Welcome to Prius Chat @emchelle . While can't answer your question myself, I wondered why you didn't use a Toyota dealer workshop to conduct your initial report. The technical wizardry that is in your Prius is beyond my simple knowledge, but perhaps @bisco or @Mendel Leisk can chip in with guidance.
  4. jerrymildred
    jerrymildred Senior Member
    11,517
    14,171
    Tampa, FL
    I'm curious what they told you on Monday, @emchelle. I just came across this as did, apparently, @RCO.
    If you still have the car at home, I think those codes, especially the C1241, suggest the possibility of a low 12V battery. Easy to check with a multimeter after the car has sat overnight. With the car off, it should read close to 13 volts if it's fully charged.
  5. emchelle
    emchelle New Member
    Austin, TX
    Three Touring
    Sorry, I meant to come back and update this!
    The issue was resolved fairly simply: when the new 12V battery had been installed, the connection with the ABS power supply hadn't been totally 'clicked' (for lack of a more technical term?) Happy Hybrid/Yost Automotive in Austin, TX, did the initial inspection and then the follow-up diagnostic; they checked the voltage on the battery, which they said looked great (I actually had the 12V battery die in my previous all-electric vehicle, so I'm a bit more familiar with that issue), and they rechecked all of the electrical connections before taking the car out for a drive again. No alarms or issues since then.
    I did e-mail Happy Hybrid after posting here last week, just to say if they had communicated more thoroughly at the initial appointment "Yes, your ABS actuator looks fine, but if these codes come back this is what the alarm will look like" then I wouldn't have had to Google "ABS problems in a Gen 2 Prius"...which is not unlike looking on WebMD for a reassuring diagnosis :confused: They e-mailed back and said that absolutely should have been explained to me, they were very sorry I had such a frustrating experience, and ultimately I was not charged anything for the diagnostic check on Monday.
    So that's that. The car is in fantastic shape otherwise, and now that I'm not worrying, I can enjoy it :D
    RCO and Mendel Leisk like this.
  6. jerrymildred
    11,517
    14,171
    Tampa, FL
    Yay!! I didn't see any mention of the 12V having been replaced. That connector is a fairly common oversight. Really glad your adventure had a happy ending. Hope you have lots of happy miles in your "new" car. My wife LOVEs her 2007.
    #6 jerrymildred, May 26, 2018
