Should Toyota acknowlege that the braking issue applies to the gen II Priuses?
Discussion in 'Gen 2 Prius Main Forum' started by Eoin, Feb 8, 2010.
  1. Eoin
    Eoin Active Member
    593
    116
    Long Island
    Should Toyota acknowledge that the braking issue applies to the gen II Priuses?
    I think they should admit this and fix the problem. I felt the brake slip in my 2005 just this morning on the way to work when I was slowing to an intersection and hit a pothole.
  2. qbee42
    qbee42 My other car is a boat
    18,058
    3,053
    Northern Michigan
    Do they need to fix the brakes or the pothole?
    Tom
  3. 2009Prius
    2009Prius A Wimpy DIYer
    2,704
    487
    63
    I think the post quoted above summarizes the problem very well. Toyota is not responsible for the pothole but should be responsible if the brake does quit working on solid ground after passing the pothole.
    3 people like this.
  4. David Beale
    David Beale Senior Member
    5,963
    1,964
    Edmonton Alberta
    I think what we have is an issue with severity. For example, if you drive -any- vehicle over "washboard" on a gravel road you will have trouble keeping control and stopping. Is that a fault?
    I submit that if the wheel is not on the road the fact the brakes are released has no effect. In fact, it may -improve- the control when the wheel does regain contact.
    So perhaps Toyota may just have to find a better fine tune of this. Or perhaps they did find the best solution on the GII and the GIII is off a bit.
  5. PriusLewis
    PriusLewis Management Scientist
    1,002
    83
    Denver Metro
    This should have been a poll. But, to answer the question, of course they should fix the faulty brakes on my 2006.
  6. swi66
    swi66 Member
    193
    Gasport, NY
    I have experienced the intermittant braking on washboard roads, or while hitting potholes. I think it is an inherant flaw in the concept of anti-lock braking and not necessarily a Prius only problem. I have felt it on my Dodge Ram. Kind of like the pulsations of the anti lock brakes do not match up with the roughness of the road........how could it?
  7. Eoin
    Eoin Active Member
    593
    116
    Long Island
    Make it a poll, by all means.
    My point in creating this thread is that the gen II have exactly the same braking issues as the 2010, but Toyota does not admit this. This is wrong.
  8. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,778
    Undisclosed Location
    My speculation is that is exactly why the public and official response concerning the 2010 Prius Brake software update is coming so slow.
    Once Toyota officially recognizes and implements an update to 2010's the simple follow up question becomes what is the difference between 2010's and Generation 2 braking systems and is the difference great enough to defend NOT making any changes to Generation 2?
    In Pre-Software update debates concerning the issue, I was told by many owners that they felt it was the exact same issue and sensation between Gen 2 and Gen 3. I honestly can't and won't speak to that as I haven't long term, driven either. I guess it boils down to how you feel. If you own "only" a Generation 2 and have never felt it was a problem...I guess it still isn't a problem.
    But Toyota will have to explain the differences between Gen 2 and Gen 3 that would warrant reacting to reported problems in Gen 3 with a software update, and NOT reacting to reported problems in Gen 2.
    If you own a Generation 2 and do think it's a problem, I'm afraid it might be a long, long battle to get Toyota to admit and recognize. Seems to me they don't really want to recall, service bulletin, the already sold 2010's let alone face the another Tsunami sized recall and all the publicity that would be created by recalling BOTH Generation 3 and Generation 2.
  9. Wizeguy
    Wizeguy Junior Member
    25
    Because it's NOT an issue.
    Prius "acts" differently than what you're used to, period. Get over it, or don't, but quit feeding the fire.
    Yes, I have experienced this braking conundrum numerous times in my 2006. Yes, the first time it happened it scared the crap out of me. So I evaluated the conditions, consulted my owners manual, read other accounts of it here, and then I went out to duplicate the conditions to make sure this was normal operation I was experiencing. It was, and it still is.
    I feel quite safe in my Prius, and I'm seriously tired of all the freakin whiners who are driving down the market value of my car.
    3 people like this.
  10. samdaman
    samdaman Junior Member
    75
    Eastern PA
    Dave -- I am sorry, but this does not quite describe the issue. 40 years driving, a dozen different owned cars [not to mention many dozens more rentals] -- the last three with my personal 07 Prius -- and the problem I experience in my Prius is in no way similar to any other 'trouble keeping control and stopping' I have ever experienced with any other car, regardless of the road conditions -- save if I were driving with all four wheels on ice.
    With four tires on the ground and all four braking, I don't care how bad the washboard or pothole or manhole cover is, with no other car I have driven do I totally loose braking the way I do in my Prius.
    That's not a difference in 'severity' -- it's a difference in 'kind'.
    3 people like this.
  11. Eoin
    Eoin Active Member
    593
    116
    Long Island
    To be clear, I think my 2005 Prius is an excellent car and I especially like the brakes - they last 100,000 miles and are very sensitive and responsive. They have the tiny glitch that has been so well described. The cause is well known. All I expect is for Toyota to admit this braking issue occurs in the gen II Prius and they should receive a software fix, just like the 2010. Sometimes the truth hurts. They have to embrace it anyway.
  12. apriusfan
    apriusfan New Member
    6,050
    205
    S.F. Bay Area
    +1. But I am less optimistic that Toyota will actually deliver a fix. Perhaps we should start a poll - Do you think that Toyota will deliver a fix to the Gen II Brake Issues? (2 options - Yes or No)
    I would love to be proven wrong about Toyota delivering a fix to the Gen II Brake Issues.
  13. Eoin
    Eoin Active Member
    593
    116
    Long Island
    Here's a prediction. At some point Toyota will have to admit that the brake issue applies to gen II Priuses and it will be worse to admit it then than if they did it now.
  14. kimgh
    kimgh Member
    297
    San Jose, CA
    Agreed. Felt it in the Prius (both of them). Felt it in my Jeep Grand Cherokee. Felt it in my Plymouth Grand Voyager.
    When the ABS system engages, things feel very funny indeed. I think it's the nature of the beast.
    So far, I've never had a problem where I didn't stop in time to avoid a crash (and I have had one or two panic stops in the Prius when the ABS engaged; one recent one was about as close as I ever hope to come!)
  15. samdaman
    75
    Eastern PA
    If it feels the same, then it is not what the people reporting the issue are talking about in the first place. In no way has any abs car I have ever driven feel like it is 'freewheeling' when the abs engages. If anything, abs in those cars wants to pitch me forward in the seat. With the Prius, I slide backward in the seat. The Prius freewheels.
    [yeah, I still love my Prius too -- but it does what people complain about in a way no other car does.]
  16. ystasino
    ystasino Active Member
    793
    49
    Tucson, Arizona
    I agree, however, there are other factors to consider:
    1) Toyota has its plate full
    2) Charges applicable with out of warranty Gen II cars
    3) Publicity nightmare for the Prius brand
    What Toyota COULD do is offer a fix for a small cost to all of us. Kind of like a software improvement.
    If so many people are bothered by this then they should keep update their vehicles' software.
    I would pay $50 to have this done, despite being under warranty.
  17. apriusfan
    6,050
    205
    S.F. Bay Area
    Are you predicting that Toyota will acknowledge a problem with Gen II Prius? I have my doubts.
  18. apriusfan
    6,050
    205
    S.F. Bay Area
    So, Toyota should get a pass for something that they knew about but chose to do nothing about? At what point should they be held accountable for their failures? 1 death? Or????
  19. qbee42
    18,058
    3,053
    Northern Michigan
    In what way is this a failure? It's certainly not a feature, but I don't know of any accidents or deaths that can be attributed to the Gen II brake issue.
    I didn't like the headlights on my Ford van, but there wasn't anything wrong with them. I think they could have been brighter. On dark nights you could even claim it was a safety issue, but they weren't bad enough to qualify as a real safety issue. Likewise with the Gen II brakes.
    Tom
  20. paprius4030
    paprius4030 My first Prius
    2,075
    292
    Ormond Beach,Fl.
    LOL that was a good one!:yo:
Loading...
