Should Toyota release PiP Gen2 nationwide, if...
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by usbseawolf2000, Mar 19, 2015.
  1. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    A regular Prius would be a better choice isn't it? In such states, Leaf or Volt would emit more, unless this person wants to reduce oil import (although 1/3 is domestic) regardless of emission.
    Right on. I think one should consider relocation before deciding to go solar and buy an electric car. Going solar now means it would be grid-tied. That means, your emission will be the average of your region. You won't get zero emission from solar.
    It seems micro-grids are coming. This would make PV system emission less if your neighbors also have PV systems.
    I think it should be the other way around. Clean up the electricity and clean plugin cars will follow. PHEVs don't even need to come as anything that uses electricity would become cleaner.
    #21 usbseawolf2000, Mar 19, 2015
  2. roflwaffle
    roflwaffle Member
    381
    77
    Orange County
    It already is, to 60 anyhow. The Leaf apparently uses ~1.4x more energy across the board compared to the PIP (30mph/60mph) in EV mode.
  3. fotomoto
    fotomoto Senior Member
    5,637
    3,812
    So. Texas
    I just looked (again) at both the Prius and PIP web pages on Toyota.com. What's the #1 feature listed on each? Price and Gas Economy numbers. What's not mentioned anywhere on the front page? Emissions. Heck, I even drilled down several submenu's and could not find even one mention about the environment.
    Toyota's primary objective is to make money by selling cars. Toyota's Audacious Goal: Double Profit by 2015
    Trollbait, frodoz737 and Paradox like this.
  4. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    Check out this book.
  5. Northeastern
    Northeastern Junior Member
    Newfoundland, Canada
    Roll out nationwide (and Canada), gas cars are stuck with the emission profile but plug in and EV's. Profile can get cleaner as the overall grid produces with more renewables.
    Newfoundland is currently engaged in a $7 billion hydro expansion which will bring our grid up to 97% renewable energy by 2017
  6. rxlawdude
    rxlawdude Active Member
    701
    219
    So Calif
    2015 Tesla Model S
    The solar roof package is kind of a joke, no? Only enough power to run a fan through the passenger compartment.
    Now, if it could generate 400W/h, and make a small but significant dent in EV range, that would be a different story. But don't hold your breath for that happening unless there is a major breakthrough in photovoltaics.
  7. css28
    css28 Senior Member
    1,566
    443
    Suburban Detroit
    I suspect that, rather than blaming photovoltaics, the watts of solar power simply aren't there in such a small area.
  8. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    Sun Power has 345W panel. Two of those should fit in the cargo with rear seats folded. They'll need 4.5 hours to fully charge PiP. Assuming PiP can charge from power fluctuating.
    If PiP2 can charge from DC solar PV panels, it would eliminate two inverter loss. DC -> AC -> DC.
  9. css28
    css28 Senior Member
    1,566
    443
    Suburban Detroit
    I question your assumption that the rear cargo area can get full sun over its entire area for 4.5 hours without taking the hatch and roof off.
  10. rxlawdude
    701
    219
    So Calif
    2015 Tesla Model S
    Two of those panels stacked in the cargo deck won't get much sun. :)
  11. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    rxlawdude likes this.
  12. Mendel Leisk
    41,427
    The prius' current solar panel has some merit: it's most effective when you need it the most, with summer sun beating down, heating the interior. Then when you use AC you've got a leg-up: with the interior cooler from the outset.
    I'd equate it to the block heater, not a complete solution, but something incremental.
  13. roflwaffle
    roflwaffle Member
    381
    77
    Orange County
    Half of one would if it were broken up into rows of individual high efficiency cells across the rear hatch, ala rear window louvers. Granted, it's probably not a whole lot. Something like .6kWh/day, with more in the summer and less in the winter, but that's still +2-3 miles on the way home. A ~15% improvement in EV range after sitting at work all day sounds like a good idea to me.
    The hardest thing about this as a project would be figuring out how to integrate it with the existing charging. It'd need a boost converter for sure, along with control circuitry and some way of tricking the battery ECU into thinking it was charging normally, so it wouldn't overcharge the pack and would kick the HVAC fans on to cool off the cabin/etc once the pack was charged up.
  14. frodoz737
    frodoz737 Top Wrench
    4,699
    2,496
    33
    With one or two exceptions do to status change, the PIP is only offered for sale in the CARB States to meet the zero-emissions :)rolleyes:) standards. Had they not offered such a product in them, they would not have been allowed to sell any vehicle in those States...at least that's how it used to be. The EV RAV was only a short run experimental partnership "additional" option...which I am more than positive was not a profit maker for Toyota Corporate.
    #34 frodoz737, Mar 20, 2015
  15. wjtracy
    wjtracy Senior Member
    11,367
    3,608
    Northern VA (NoVA)
    I don't really have any idea why Toyota picked the 14 states, but I agree more CARB and not clean elec. MD has quite high coal%. If it was CARB, you'd think CARB PA would have been on the list. Instead they picked non-CARB VA, I suspect because at the time, VA was in top 5 states for Hybrid sales (probably due to VA HOV incentives which were weakened in 2011 but still exist for some "grandfathered" owners). I've also since learned Baltimore MD is largest car import port in the US, so I don't know if PIPs come into MD. Also DC is major market but they have to buy in VA or MD.
    #35 wjtracy, Mar 20, 2015
  16. css28
    css28 Senior Member
    1,566
    443
    Suburban Detroit
    Toyota has a history of retricting car configurations regionally.
    It's been decades since you could buy a Camry with a manual transmission in his area.
  17. bisco
    51,901
    do they still make one?
  18. Tideland Prius
    16,555
    The PiP is currently available across Canada.
  19. fotomoto
    5,637
    3,812
    So. Texas
    Including the tar sands region?
  20. FL_Prius_Driver
    FL_Prius_Driver Senior Member
    4,319
    1,527
    Tampa Bay
    I
    Toyota would not base the PiP availability on the EV component of pollution while maximizing sales of gas guzzlers everywhere.
    Trollbait likes this.
