Should you buy the GEN 5 car care nut says so!
Discussion in 'Gen 5 Prius Main Forum' started by samsprius1, Jul 15, 2023.
  1. theRob
    theRob Member
    98
    116
    2023 Prius
    It seems to be the case according most people on here. Definitely a good thing. On my CT200h it was usually off by 3-5 mpg’s. I keep forgetting to check the tank average meter before I fill up and compare it to Fuelly, because I have my meter set to trip average. Before my next fill up I will definitely check.
  2. Rmay635703
    Rmay635703 Senior Member
    2,669
    1,687
    Somewhere in Wisconsin
    2013 Chevy Volt
    My Chevy Cobalt XFE with mechanical everything has been much more reliable and simple to fix than I expected.
    Sadly it’s also prone to non-body components rusting and requiring replacement (parts are still moderately cheap though)
    42mpg I guess is worth the cheaper repairs, sadly the ac failed a few weeks ago with a massive leak, finding a cheap mechanic that does AC is no longer possible, I’m almost tempted to throw parts at it since I can replace much of the system for less than the inspection cost.
    Then rent an Autozone AC die pressure tester and make sure I got the correct o-rings and valves replaced
    51,896
    LOL, so was my 1972 fiat 124
  4. Rmay635703
    2,669
    1,687
    2013 Chevy Volt
    I have a 1985 Yugo in the garage just needs a front brake caliper
    raqball likes this.
  5. raqball
    raqball Junior Member
    33
    34
    Pacific Northwest
    2023 Prius Prime
    XSE
    Hey, I actually had an 87 Yugo GV Sport.. LOL
