Show off your Rims
Discussion in 'Prime Accessories and Modifications' started by 5herw1N, Mar 27, 2018.
  1. frankfrank
    frankfrank New Member
    Nebraska
    Got some Konig Hypergrams (17x8 +40) put on the car today and wrapped them in Nokian WR G4s (215/45/17).
    A lot of informative posts, and posters, in here!
  2. Rob43
    Rob43 Senior Member
    1,269
    894
    VA, BMW Race Car, BMW R1200R, BMW 330Ci, Ford F350
    2013 Prius v wagon
    ^ Congrats, they look good.
    I see you live in Nebraska, this particular Nokian will work well for you in poor weather / snowy weather, but because it's virtually a snow tire in design & concept it will provide you with a Large Loss in MPG.
    Rob43
  3. frankfrank
    Nebraska
    Thanks, Rob. I’m going to keep an eye on the MPG loss and see what kind of hit the MPG takes.
  4. jw242
    jw242 New Member
    2018 Prius Prime
    Hello
    Hello. I just got my Prime. I am new to this. If you don't mind, I might want to copy your setup.
    Where did you purchased the Koenig Intention Wheels?
    After installing your new wheels, did you lower your vehicle? If so, how low did you go?
    Did you use any spacers? If so, can you tell me what size spacer you use?
    Please. Thank you.
    -J
  5. MSAGRO
    MSAGRO Active Member
    212
    177
    Portland Oregon
    Discount Tire.
    No lowering, no spacers or adapters.
    215/50 R17
  6. jw242
    jw242 New Member
    2018 Prius Prime
    Did you use hub rings?
  7. Priuskp
    Priuskp New Member
    Oakland
    2018 Prius Prime
    2018 Prius Prime with 18 x 8 wheels on Pirelli P zeros. Wheels are gunmetal silver.
    eddiesudz, EvenSteven and toyopri808 like this.
  8. MSAGRO
    212
    177
    Portland Oregon
    Nope. Direct fit.
  9. Jer707
    Jer707 New Member
    Bay Area ca
    2018 Prius Prime
    85064CFF-F9B0-4DBA-9260-8C1636EB7231.jpeg Just installed some rsr springs to go along with the konig dekagrams!
    7585770C-74FC-4BC3-AE9A-0246D6BEDA0F.jpeg E0923337-AA8B-4633-BFC8-C3C9EEBB891D.jpeg
    #109 Jer707, Nov 2, 2018
    thatguymichael, a8up and JspecPrime like this.
  10. MSAGRO
    212
    177
    Portland Oregon
    9CD588F4-992E-4B1D-BFA9-46D5EA793D72.jpeg Those wheels look great what are the specs? Also I see you also did your roof like is a vinyl or paint.
    Vinyl for about a year and decided to have something more durable so I put it in an acrylic enamel with two coats of clear.
    Jer707 likes this.
  11. Jer707
    Jer707 New Member
    Bay Area ca
    2018 Prius Prime
    Thanks! They are 17x8 on 215 50 17’s. I actually got this tire size thanks to you! Yes, I got the 3m gloss black wrap. Your roof looks great! I may do that as well after the wrap starts to wear off.
    MSAGRO likes this.
  12. toyopri808
    toyopri808 Active Member
    226
    115
    Jer707 likes this.
  13. Jer707
    Jer707 New Member
    Bay Area ca
    2018 Prius Prime
    Thanks! You should. Makes a huge difference in my opinion
  14. toyopri808
    226
    115
    I recently put wheels on too and a wrapped roof would be icing on the cake!
    iPhone ?
  15. Jer707
    Jer707 New Member
    Bay Area ca
    2018 Prius Prime
    Yep! Your car looks great! Wrapped roof would complete the look imo
    toyopri808 likes this.
  16. kev909
    kev909 Junior Member
    LA-IE
    2018 Prius Prime
    I can finally contribute to this thread. I been browsing for a while, and finally got some wheels.
    OZ Ultraleggera 16x7" +35 with 205/55-16 Continental TrueContact Tour.
    Wheels are 15 lbs
    Tires are 21 lbs
  17. PHV PLS
    PHV PLS Member
    157
    73
    2017 Prius PHV
    Are you staggered or squared setup?
  18. Jer707
    Jer707 New Member
    Bay Area ca
    2018 Prius Prime
    Squared
  19. Rob43
    Rob43 Senior Member
    1,269
    894
    2013 Prius v wagon
    Actually your 205/55-16 Continental TrueContact Tour tires are 19.9 lbs which is even better. Please track & post up any MPG loss % you get because you have an excellent test bed based on both your wheel and tire combo.
    Rob43
  20. a_gray_prius
    2,927
    768
    IL
    Just when I thought Rotiforms were for VWs and Audis slammed to hell and designed to get as many tickets as possible at h2oi...
Loading...
