Shudder, cylinder 3 misfire, check engine light
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Groundpounder17, Mar 6, 2019.
  1. Muneeb
    Muneeb Junior Member
    22
    23
    SURREY
    Business Edition
    If I was you I wouldnt touch water pump as they last longer than 300000miles providing you change the coolant at every 100000miles. Anyway if you still want to go ahead please use Aisin as they are the manufacturer of toyota water pump so when you remove the old water pump it will have Aisin Japan written on it. I have seen someone selling the genuine toyota water pump for £157 from japan.
  2. Mendel Leisk
    41,425
    Just thinking strategy: don't put too many routine chores between you and getting the head gasket replaced. Maybe the plugs too, since you're right there. Do that, button it up, and drive it or two, see how it goes.
    Then, address the rest, and prioritize, maybe start with the EGR and intake manifold.
  3. mjoo
    mjoo Senior Member
    1,155
    1,326
    Michigan
    Has that been your experience? Other PCers have found them to fail before 200k?
    I plan on changing mine around 150k so that it doesn't take down my head gasket.
    Pixel XL ?
    SFO and m.wynn like this.
  4. Groundpounder17
    104
    77
    AR
    My water level dropped almost 3/4” since yesterday and my oil is a little milky. I’m afraid a head gasket change is now a given. Should I order the Toyota head gasket or get the Beck/Arnley three layer head gasket?
  5. The Critic
    The Critic Resident Critic
    3,193
    2,333
    CA
    Get the Engine Overhaul Gasket Kit from Toyota. It includes all of the gaskets that you will need; you will need more than just the headgasket. The o-rings in the cyl head, timing cover and camshaft areas will be rock hard. You will also need the intake and exhaust manifold gaskets, valve cover gasket, dipstick tube seal, thermostat gasket and valve stem seals - all of which are included in the engine overhaul gasket kit.
    Cost is $259 msrp for the kit. Part #04111-37315.
    edit: corrected part number
    #25 The Critic, Mar 7, 2019
  6. The Critic
    3,193
    2,333
    CA
    Aisin is the supplier of water pumps to Toyota. When you buy the Aisin pump for this application, it is the same pump as the one from the dealer but with the Toyota emblem ground off.
    Beck/Arnley does not make any parts - they are a reboxer.
    m.wynn and Raytheeagle like this.
  7. Groundpounder17
    104
    77
    AR
    Thanks. I’ll get it all ordered and get ready to dive in.
    Do you think I should go ahead and get the water pump or is that the least of my problems right now?
  8. tweedle99
    tweedle99 Member
    123
    68
    Round Rock, TX
    They're the same. I bought the B/A one a few months ago. B/A one actually has longer warranty i think 3 vs 1 yr. B/A one still has the aisin sticker on it.
    SFO and The Critic like this.
  9. Mendel Leisk
    41,425
    Should the part number be ...-37315 ? (See attached TSB's regarding piston/ring replacement for oil consumption, they list the gasket kit in the second TSB.)
    Also, assuming you got that kit: did it come with a packing list, parts numbers and descriptions of the contents? If so, could you post a scan or picture? Or pdf if you got it? Thanks.
    McGeorge Toyota is discounting the kit, assuming it's the one with part number ending in "5", only $170~:
    Overhaul Gasket Set - Toyota (04111-37315) | Toyota Parts
    m.wynn and Robert Holt like this.
  10. Groundpounder17
    104
    77
    AR
    I ordered the kit and yes it is updated part number 04111-37315. It should be here next week. I’ll follow up and answer the questions when I get it in hand. I ordered already from Canelback Toyota. I think I paid $189
    The Critic and Mendel Leisk like this.
  11. The Critic
    3,193
    2,333
    CA
    You are correct- I just re-checked my receipt.
    No, the kit do not come with a packing list. Some items are packaged separately and identified, but most were not. Basically, most of the small gaskets are in one bag and the bag is laminate-wrapped against the headgasket.
    It is critical to save the old gasket so that you can match it up with the appropriate new one in the kit.
  12. The Critic
    3,193
    2,333
    CA
    I would also order head bolts, two tubes of fipg black, thermostat and spark plugs if you have not done so. Proper clamping force is critical and regardless of Toyota’s position, I would not reuse those bolts.
    Also, CRC gasket remover, plastic razor blades and a fine wire brush is your best option for cleaning the gasket surfaces.
  13. Groundpounder17
    104
    77
    AR
    I’ll be sure to keep the gaskets as you recommend. And I’ll order the head bolts, 2 tubes of FIPG black and I’ll pick up some CRC gasket remover.
    I already ordered the thermostat and changed our plugs about 300 miles ago. I’ll check the plugs but I’m hoping I haven’t fouled any.
    What is the consensus on the water pump? Hold off or drop another $250 now?
  14. cnc97
    cnc97 Senior Member
    1,422
    1,535
    38
    Evansville, IN
    I am still running the water pump off the engine of mine that failed, as the newer engine I bought came without one. No issues since installation. Maximum coolant temp I have seen is 196, and that was running 75+mph uphill on a 7.5 percent 2 mile grade.
  15. The Critic
    3,193
    2,333
    CA
    Yes on the water pump. I only drove for 50 miles and my plug for cyl #2 was completely fouled (and the plug was only 5000 miles old).
    Do you have an angle torque wrench? If not, you may want to invest in one. The head bolts are 36 ft lbs plus 90 deg plus 45 deg. As an alternative, you can mark using paint and guestimate.
  16. The Critic
    3,193
    2,333
    CA
    I also replaced the intake VVT gear on mine. Mine rattled sometimes rattled for a second during cold starts. It is a but pricey, but it is easy to replace once the timing chain and cam housing is off.
    m.wynn likes this.
  17. Mendel Leisk
    41,425
    Eyeballing 90 and 45 degrees should be close enuf?
  18. The Critic
    3,193
    2,333
    CA
    It is up to you, but I wouldn’t...
    I went out and purchased a 1/2” angle torque wrench just for this repair.
    Consistent clamping force is critical for proper headgasket sealing.
    Gshadow325, m.wynn and Raytheeagle like this.
  19. padroo
    padroo Senior Member
    2,763
    2,252
  20. The Critic
    3,193
    2,333
    CA
    That works too!
    Raytheeagle likes this.
