Shudder, cylinder 3 misfire, check engine light
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Groundpounder17, Mar 6, 2019.
  1. Groundpounder17
    104
    77
    AR
    A couple more 826DF143-18C9-44B0-A7A5-71702834E6E2.jpeg 80403A4D-B904-4D7A-B551-EF250A66F01D.jpeg
  2. Groundpounder17
    104
    77
    AR
    4B2DC17C-98D7-4AE3-A1CC-5C444949C670.jpeg E8F5C000-FD83-4C8B-93F7-30C218963803.jpeg 4B2DC17C-98D7-4AE3-A1CC-5C444949C670.jpeg Intake manifold, nice and clean
    ASRDogman and Robert Holt like this.
  3. Robert Holt
    Robert Holt Senior Member
    1,313
    889
    Thanks for reference! Had never heard of the Bauschinger Effect. So my fears of breakage due to re-using a pre-used and slightly stretched bolt appear to be groundless as long as the bolt has been used arounf 4-5 times max, and I suppose the elongation test specified by Toyota would ensure that you don’t use it up to the 10th cycle (or maximum stretch) where failure would occur. Have to say, I understand it much better now, but still don’t like the idea of stretching headbolts very much.
  4. Groundpounder17
    104
    77
    AR
    I went ahead and ordered new head bolts. As much work as I have in this I consider head bolts and taking the head to the machine shop to be minor expenses.
  5. Groundpounder17
    104
    77
    AR
    While I’m in here I’m wondering if there is a good way to check cylinder wear. Without facing the problem of a bent rod when does one decide to rebuild the engine? I didn’t have the compression checked before I started tearing it down.
  6. mjoo
    mjoo Senior Member
    1,150
    1,326
    Michigan
    Camera? Are the cross-hatch patterns there or polished out?
    Pixel XL ?
  7. Groundpounder17
    104
    77
    AR
    I’ll look when I get home
  8. Groundpounder17
    104
    77
    AR
    They are still there
    mjoo likes this.
  9. Groundpounder17
    104
    77
    AR
    Is there anything I can do to clean the rings? I’m guessing they really need replacing? At this point should I consider pulling the rest of the engine and getting rings? How much more work would be involved to pull the engine? I’m guessing not much more.
    Before this it was using about a quart of oil every 10k miles, give or take.
  10. padroo
    padroo Senior Member
    2,763
    2,252
    A visual inspection is a good start but to do it right the pistons need to be removed and each cylinder checked for taper and out of round against the specs for wear. This video shows the machinist process.
  11. Groundpounder17
    104
    77
    AR
    To do this I would need to pull the short block and if I did that I would rebuild it.
  12. Groundpounder17
    104
    77
    AR
  13. cnc97
    cnc97 Senior Member
    1,422
    1,535
    38
    Evansville, IN
  14. Groundpounder17
    104
    77
    AR
    Any kind of cleaner I could use so I could let the piston tops soak while this is happening
    mjoo likes this.
  15. cnc97
    cnc97 Senior Member
    1,422
    1,535
    38
    Evansville, IN
    Seafoam would do the trick. Let it soak for a short amount of time
  16. mjoo
    mjoo Senior Member
    1,150
    1,326
    Michigan
    I heard seafoam, MMO and ATF work well.
    There are comparisons on YouTube.
    Pixel XL ?
  17. Groundpounder17
    104
    77
    AR
    I poured Seafoam in and it didn’t seem to change level the first hour but I checked 5 hrs later and the 2nd cylinder from the left when looking at the engine from the front has slowly leaked down
  18. Groundpounder17
    104
    77
    AR
    What’s an acceptable difference on the pistons at the top? My 1 and 4 are the same. My 2 and 3 have a 1/16” difference. I’m trying to go back together with it today after being delayed by my job since Tuesday.
    What will it do if I reassemble and run it with the #3 being a tad short? I’m almost certain it’s a slight bent rod but due to work I’m kind of in a bind and need to get back to driving soon
  19. Groundpounder17
    104
    77
    AR
    As you can see in the pic, piston 3 is short by 1/16”. Now the question is do I rebuild the short block, buy a new short block, or just try to reassemble and see how it performs? At this point I don’t want a used engine unless I could find one with extremely low mileage.
    Raytheeagle likes this.
  20. Groundpounder17
    104
    77
    AR
