Shudder, cylinder 3 misfire, check engine light
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Groundpounder17, Mar 6, 2019.
  1. padroo
    padroo Senior Member
    2,763
    2,252
    A couple of people here have installed Gen 4 Prius engines in Gen 3 cars. There should be a supply of low mileage engines for sale. They will chime in on this I am sure.
  2. cnc97
    cnc97 Senior Member
    1,422
    1,535
    38
    Evansville, IN
    I’m fairly certain that’s a bent rod on number 3. I’d venture to say that you would get a noise on that cylinder when running if you reassemble this engine as is. I’m pretty sure, in retrospect, that is the mystery noise mine had when I got it. Mine was on number one though. You already have the head and things out of the way. Pull the short block. A rod is $70 thru Toyota. Or swap in a lower mile Gen 4. Since you have the gaskets and such to reassemble yours, put your head on the Gen 4 shortblock and put this one to bed.
    SFO and Raytheeagle like this.
  3. Groundpounder17
    104
    77
    AR
    What’s the difference between the short block of a gen 4 and the later gen 3 with the updated piston/ring set?
  4. cnc97
    cnc97 Senior Member
    1,422
    1,535
    38
    Evansville, IN
    The Gen 4 shortblock has added stainless steel insulation in the water jackets, possibly to “maintain” coolant temps. I’m just guessing at the actual purpose, but yes they are there.
    The newer Gen 3 engines, if you get a used one, at least in my area, are still priced several hundred dollars over the Gen 4. Is it logical that the price is more for an older engine? No. But the fact remains that the Gen 4 swap into a Gen 3 is still not a mainstream idea, and most, if not all yards get a premium price for the Gen 3 engines, run tested or not.
  5. The Critic
    The Critic Resident Critic
    3,193
    2,333
    CA
  6. Avi's Advanced Automotive
    Avi's Advanced Automotive Independent hybrid repair shop
    776
    363
    I'm thinking a new connecting rod and updated pistons and rings.
  7. Avi's Advanced Automotive
    776
    363
    BTW, I've changed a couple bent connecting rods on these and they came out fine.
  8. The Critic
    3,193
    2,333
    CA
    Can the upper oil pan be removed without removing the short block?
  9. cnc97
    cnc97 Senior Member
    1,422
    1,535
    38
    Evansville, IN
    If I remember correctly, I think some of the bellhousing bolts pass thru the upper oil pan. I no longer have my old engine to look at though.
    But if it was me, I’d pull the shortblock for changing the rod.
    Raytheeagle and The Critic like this.
  10. Groundpounder17
    104
    77
    AR
    So for me to remove the short block there really isn’t much left. Any tips on removing it from this point? Anything special to know or worry about removing the ac condensor?
  11. Groundpounder17
    104
    77
    AR
  12. cnc97
    cnc97 Senior Member
    1,422
    1,535
    38
    Evansville, IN
    No need to remove the ac. I unbolted mine, wrapped a bungie cord around it, and hooked it to the radiator support.
  13. cnc97
    cnc97 Senior Member
    1,422
    1,535
    38
    Evansville, IN
    You do have to disconnect the 12v(small black connector) and the HV cable (orange plug though. Just for clearance issues.
  14. Groundpounder17
    104
    77
    AR
    So just unbolt it from the block and pull the ac condenser out of the way?
  15. cnc97
    cnc97 Senior Member
    1,422
    1,535
    38
    Evansville, IN
    Yes. That’s all you need to do
  16. Groundpounder17
    104
    77
    AR
    Any recommendations for anchor points to pull it?
  17. cnc97
    cnc97 Senior Member
    1,422
    1,535
    38
    Evansville, IN
    The short block only weighs about 100 pounds. Use a couple of the head bolts at opposite corners to attach your lifting device.
    Groundpounder17 likes this.
  18. Groundpounder17
    104
    77
    AR
    Thanks
  19. Avi's Advanced Automotive
    776
    363
    I think so. The last one I did was #2 and I only had to remove the lower oil pan and oil pump. I'm pretty sure you can remove the upper oil pan without removing the engine. Just don't disturb the rear oil seal and maybe put a thin film of FIPG/silicone where the seal contacts the upper oil pan.
    Groundpounder17 and The Critic like this.
  20. Groundpounder17
    104
    77
    AR
    If I pull and rebuild it do you have any idea how much I’m looking at cost wise? How would a rebuild compare quality-wise to a new short block?
    I’d rather rebuild it but if I do that I want to do it right. I know I would need a ring set, 1 connecting rod, and should go ahead and get new pistons. I don’t see anywhere where Toyota allows for ordering oversized pistons. Does Toyota carry those?
    What about rod bearings, a new rear seal or connecting rod bolts? Should I replace those or wait and see. I’d really like to get the parts ordered soon so I could rebuild if that looks like my best option
