Shudder, cylinder 3 misfire, check engine light
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Groundpounder17, Mar 6, 2019.
  1. The Critic
    The Critic Resident Critic
    3,193
    2,330
    CA
    Thanks. I finally got around to ordering the correct socket today:
    1/2" Drive Metric 10 mm Lexus®/Toyota® Double Hex Socket Driver
    Since Snap-On does not charge for shipping (only charged for tax), the cost actually came out to be less than the Assenmacher ASSS3054X-12 which has been on backorder (for me) since March.
    Now I should be all set to go for the next Prius Head Gasket job.
    SFO, RMB and Raytheeagle like this.
  2. wheezyglider
    wheezyglider Active Member
    247
    178
    SF Bay Area
    When I google ASSS3054X-12 it comes up with a 12mm socket vs. 10mm for that snap-on? Maybe you're lucky it was backordered...
  3. The Critic
    3,193
    2,330
    CA
    There seems to be some “debate” on how it should be described.
    I have the “10mm” assenmacher socket (ASSS3054X-10) and it was clearly too small.
    Raytheeagle and wheezyglider like this.
  4. johnso21
    johnso21 New Member
    Georgetown
    holy crap...you guys dont mess around! Groundpounder have you done this kind of stuff before? I mean...dang, i'm all for DIY videos on youtube but...this is hardcore! I'm impressed man.
    edit: How did you learn to do all this rebuilding etc? In terms of removing the whole engine from the car?! I could probably do that but there is no way in hell I'd be able to put it all back together!
