Shudder: need help diagnosing
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by geoffdaddy, Aug 25, 2025.
  1. geoffdaddy
    geoffdaddy Junior Member
    North Alabama
    Hey guys, I tried searching around the forum about a "shudder" similar to mine, but came up empty handed so I figured I'd check with a new topic to see if members have some ideas for me to check...
    I have a 2012 Prius V that we bought as a lease turn in with 32kmi on it in 2015, and she now has about 189kmiles. We had the infamous leaking head gasket issue about 15k miles ago now. At that time I replaced the head gasket and the water pump (the impeller plastic covering on the magnet on it was cracked and binding slightly in the housing, so I replaced that at the time even though it was still working) along with the typical stuff you'd change in a head gasket replacement job (lap valves, new valve stem seals, new gaskets everywhere, etc). Ever since and even before the head gasket was replaced we sometimes experience a "shudder" at low speeds, say 20-40 mph while light on the throttle. It kind of "feels" like a misfire, but it doesn't sound like one plus I have on occasion noticed this phenomenon while in EV mode. This is different than the for sure misfire that would happen on cold startup due to the head gasket leaking coolant into Cylinder 1. No codes are being thrown by the computer and no flashing check engine light or anything when it happens.
    The other symptom I have noticed is lessening fuel economy. When we first got the car it would reliably give us 42mpg regardless of driving style (45ish when we first got it the first year). Over the course of a couple of years this has dropped and now we are down to 35-36mpg. I think the fact that I've observed this situation shudder a couple times when ICE engine not running indicates it's something related to the inverter, or hybrid drive rather than the gas motor. The gas motor is buttery smooth at idle and startup or if you put it in service mode and give it gas.
    Has anyone else had similar experience? I am wondering if it could be related to maybe a winding arcing in one of the motor generators or something like that. It doesn't happen frequently but it does happen probably 3 or so times a week, and only when hot. It is about time to change the drive unit oil again so I'm tempted to do that and see if the problem gets better (i.e. thinking if there's enough material floating around in the fluid maybe that makes the problem worse). I'll take any suggestions though of places to look.
    Apart from the head job and the (thankfully) leaking brake booster/ABS system TSB issue (that was fixed with 1000 miles and <30 days left on the warranty!) the car has treated us well.
  2. geoffdaddy
    North Alabama
    Oh yeah... when the shudder does happen, if you press the accelerator down just a little bit further, that's usually enough to get it to stop, and let back off just a little and sometimes it'll come right back. Sometimes if you goose it pretty good and then drop the pedal back to where you were, it'll stop too when it does. It's very random.
  3. geoffdaddy
    North Alabama
    Aalso considered maybe it could maybe have to do with the damper between the motor generator and gas engine perhaps a bit weak? Don't hear any weird rattles or anything though, so I do not know. I'm grasping.
  4. Brian1954
    Brian1954 Senior Member
    2,684
    1,072
    South Central PA, USA
    Did you clean the complete EGR system when you replaced the headgasket?
  5. geoffdaddy
    North Alabama
  6. Mendel Leisk
    42,346
    Bent piston arm?
  7. geoffdaddy
    North Alabama
    I don't think so... see comment about it doing this while engine isn't running.
  8. 2015V-BadHG
    2015V-BadHG Junior Member
    26
    Portsmouth NH
    2015 Prius v wagon
    IDK. I've got a similar shudder when ICE comes back on at certain speeds. Some times its worse than other times.
    my 2015 V with 256K. Recent HG, water pump, ETC. On my V there was obvious scoring on middle two cylinders.
    While pistons appeared to all return to same level TDC I didnt check where the bottomed. I am assuming bent connecting rods.
    I'm gonna drive it until it dies. Oh, my MPG is 38-40 pure Hwy. mid 40's to almost 50 mixed use.
    Haven't yet gotten to run Dr. Prius battery testing.
    Pete
  9. rjparker
    rjparker Tu Humilde Sirviente
    11,103
    6,967
    Texas Hill Country
    The loss of mpg is consistent with a weak hybrid battery with minimal capacity to store regen energy. This will also cause sluggish acceleration when the hv battery has low charge based on the bar graph..
    Brian1954 likes this.
  10. geoffdaddy
    North Alabama
    I didn't check bottom of stroke on mine, but at the top of stroke they all matched up. I did a compression check before and after the job and the numbers were even and improved across the board, and the cylinder walls all looked brand new still.
    Your MPG is way better than mine. heh
  11. geoffdaddy
    North Alabama
    That's kind of what I assumed is going on there. I have Dr. Prius but not really saavy about what the results indicate. I may tear into the pack and replace some modules when time comes, but for now I'm suffering with the reduced economy.
    Seems to have plenty of pep when you stomp on it any time regardless.
