Shuddering/Shaking but EGR cleaned - 2010 Prius
Discussion in 'Gen 3 Prius Main Forum' started by Oma9227, Oct 19, 2025.
  1. Oma9227
    Oma9227 New Member
    Ontario
    Hello
    310K KMs.. (195K Miles for US friends). Car shudders very noticeably/audibly when below 20KM/h on low battery, on 2 bars.
    Once battery charge is above 2 bars, the shudders reduce in intensity significantly but it is still there as long as ICE is running. I can tell because as soon as I drop into using electric engine only, car is fairly quiet.
    EGR was cleaned out as per previous owner.
    The low battery shudder was always there since I bought it earlier this year. The shudder at all times is recent.
    What are some /likely possibilities here?
  2. PriusCamper
    PriusCamper Senior Member
    13,402
    5,412
    Pacific Northwest, USA
    Is the shudder worse when engine is cold?
    Are you having to add coolant regularly?
    Any check engine lights (error codes) or other symptoms?
  3. Oma9227
    Oma9227 New Member
    Ontario
    No, the engine temp doesn't seem to matter regarding shuddering.
    Coolant levels are within threshold and not running low/refilled.
    No engine lights either
  4. PriusCamper
    13,402
    5,412
    Intermittent shaking? Or consistent shaking when down to two bars?
    This points to issues with motor generator, but there hasn't been an issue at all with that part of the Prius since 2000-2003.
    Maybe @ChapmanF might have some input?
  5. Oma9227
    Oma9227 New Member
    Ontario
    When it's at 2 bars and charging kicks in (40% approx) there is consistent shuddering unless I speed up enough like 30-40km/h. It's still there then but less.
  6. bisco
    52,773
    any trouble lights?
    maybe the previous owner didn't do a good job with the egr circuit
  7. bisco
    52,773
    then again, could it ne plugs/injectors/throttle body/o2 sensors? some things throw codes, others don't.
    i have read that when the head gasket first begins to leak, it doesn't lose any coolant
  8. Mendel Leisk
    42,257
    Back here you were saying it wasn't, at 191k when you acquired it:
    2010 Prius Mileage Going Worse | PriusChat
    A moot point now I think. I would at least check the EGR pipe condition (goes between EGR valve and intake manifold, and the intake manifold itself. See top two links in my signature for more info. (on a phone turn it landscape to see signatures)
    That said, it sounds like head gasket. Are you keeping an eye on the coolant level in the engine reservoir? I'd also do a borescope inspection of the combustion chambers, day after driving, and preferably with engine coolant system pressurized, to accelerate any head gasket coolant leakage.
    If you're still reluctant to DIY (per the link above), it might be time to ditch it.
  9. Oma9227
    Oma9227 New Member
    Ontario
    Yeah I was able to ask the seller after posting that thread - he confirmed he did the EGR, said it was cleaner than expected. Inverter coolant level seems to be consistent and not dropping.
    I have seen a few videos on youtube with cars of head gasket issues - and my car doesn't sound like that at all. Shuddering/shaking only happens when driving - not when stationary
  10. Mendel Leisk
    42,257
    I'd want to verify. Especially "cleaner than expected": maybe he didn't touch the intake manifold (with EGR passages, small diameter), one per intake port), and/or just cleaned the pipe twixt EGR valve and intake manifold. Who knows...
    Did you mean to say engine coolant? That's the concern.
    Round about your miles is when EGR-neglected third-gens fail, reliably.
  11. Oma9227
    Oma9227 New Member
    Ontario
    Yeah I dont know what he meant - those were his words.
    Sorry - yeah - I am not seeing the engine coolant loosing to the point I would have to refil.
    I was able to find a hybrid/Prius mechanic in Toronto area - so will have someone look at it.
    Mendel Leisk and bisco like this.
