shutting down the prius c while ICE still running?
Discussion in 'Prius c Technical Discussion' started by deckbuild, Apr 26, 2014.
  1. deckbuild
    deckbuild Junior Member
    42
    Singapore
    is it advisable to shut down the car while the ICE still running?
  2. AEROENGR
    AEROENGR Junior Member
    57
    Connecticut
    My 2013 Prius C2 with a total of 4512 miles made an engine noise on start-up. The noise lasted for about 3 seconds after a cold start at 59F ambient temperature. It was a soft clanging sound at about 4 or 5 Hz and there was no engine vibration - the start was smooth. I had moved the car from the driveway to the garage the day before and shut down the engine after it had been running for about 15 or 20 seconds following a cold start. The noise occurred on the first start the next day. I also own a 2011 G3 and I am well aware that the liftback should not be shut down until the warmup cycle is completed. Since I had heard of no similar problems with the C, I shut the engine down without allowing it to complete the warmup cycle the day before. From now on, I will operate my C as I do the G3 - no engine shut-down until the warmup cycle is completed.
