Siberia hole
Discussion in 'Environmental Discussion' started by bwilson4web, Jul 16, 2014.
  1. bwilson4web
    16,527
    Gigantic hole mysteriously appears in Siberia. What caused it? (+video) - CSMonitor.com
    There will probably be a 'gag' thread in Fred's shortly but I figured the adults might be curious in what happened. Permafrost cap melt letting some accumulated high-pressure escape?
  2. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    volcanic activity...
  3. Robert Holt
    Robert Holt Senior Member
    1,313
    890
    I understand melting permafrost releases methane, a potent GHG, so that sounds bad if it is a part of a positive feedback loop in the global temperature system.
  4. fuzzy1
    10,701
  5. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    It's the entrance hole to the Lizard Kingdom :)
  6. GregP507
    GregP507 Senior Member
    3,002
    481
    I believe this was a gas well that went wrong and blew out. As the escaping gas burned, it eroded the soil around the hole, making it larger and larger over time.
    It's not surprising that nobody owned up to this, and probably walked away from it. Here in Alberta, we've had some big blowouts over the years. One of them was drilled in 1916, and spewed gas and salt water for 87 years before it was finally capped in 2003, at a cost of $5M.
