Side curtain airbag deployment location
Discussion in 'Gen 3 Prius Technical Discussion' started by PortlandHiker, Aug 21, 2015.
  1. PortlandHiker
    PortlandHiker Junior Member
    26
    Portland
    Where do the side curtain airbags deploy from in the 2015 model? I see some plastic trim between the side and front windows that say "SRS curtain airbag". Does the airbag pop out from behind this?
    The reason I ask is because I have a soft rooftop carrier for a one-time trip. Since I don't have roof rails, I need to run straps through the interior of the car to hold the carrier in place. I want to make sure the straps don't interfere with the airbags. I found a thread on PriusChat discussing this situation, but it applied to an older model. In the 2015 model I don't see how the straps will interfere with the airbag if it deploys from behind the plastic trim mentioned above.
  2. drysider
    drysider Active Member
    823
    337
    Liberty Lake WA
    The owners manual for the 2012 has two fairly detailed pictures showing the airbag locations. I do not know about yours....
  3. pauerbach
    pauerbach Member
    101
    34
    You can see where it deploys in this crash test video:
