Side Marker Lights in 2011 Prius - Difficult to Replace?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Pandas Andpresents, May 13, 2018.
  1. Pandas Andpresents
    Pandas Andpresents Junior Member
    34
    Danbury, CT
    I went to the Toyota dealership recently when a check engine light came on after a long road trip. I finished the drive home that morning and drove directly to work. After work, I turned the car on and the check engine light appeared. Ended up being a loose gas cap - $60 "to reset the computer". (I would generally check that but assumed after such a long trip that it had to be more serious. Does the dealership have to reset the computer for the check engine light to go out or would it go out on its own once the gas cap is properly closed? We hadn't gassed up for three days and were driving around that long without a light, which seems strange. In any case, it's been about two weeks and the light hasn't returned.)
    I was also told that my license plate lights and all of the side marker lights on the car are blown out. The dealership wanted to charge me over $100 to replace the lights. I told the guy I would do it myself.
    In googling for how-to videos, the first ones that come up instruct that the whole back plastic panel of the car has to be torn off to access the license plate lights, many clips break in the process unless you have a special tool to remove them, etc. I don't know if these were instructions for an older model or people who don't know what they are doing. I found the guide below and changing the license plate lights turned out to be pretty easy.
    2010-2015 Toyota Prius Hybrid Hatchback Common Problems, Repair Guides, & Vehicle Maintenance DIY Instructions
    The hardest parts are twisting the lights out/in (counterclockwise) and polarity (had to turn a bulb around after initially installing it because the polarity wasn't right). I used LED lights that I ordered on Amazon. I think I brought 10 for $5 or something like that. Very happy with the results.
    The blog also contains instructions for common Prius repairs:
    I also have to replace the side marker lights. The Prius manual makes it sound quite complicated on one side. Something about unscrewing something related to the engine or fan (can't remember).
    Is changing the side marker lights difficult? Any tips before I try to do this?
    Thanks for your time, everyone!
    samochod likes this.
  2. The Critic
    The Critic Resident Critic
    3,193
    2,319
    CA
    The passenger front side marker bulb can be a somewhat difficult. If you unbolt the coolant reservoir and move it out of the way, the job becomes considerably easier.
    iPhone ? Pro
    Mendel Leisk and Raytheeagle like this.
  3. Jumping Jehosaphat
    Jumping Jehosaphat Junior Member
    I replaced the license plate bulb by removing the small panel. Had to use a wrench to unlock the bulb though. It was super tight, and even my male friend couldn’t remove it with bare hands. Neither of us could do the passenger side marker light. Impossible to get a good grip on. It’s similarly stuck and cannot be turned without a large amount of force. Not enough space to do it without removing the coolant reservoir, whose bolts even look unmovable to me on my car. All the videos I watched, they just pop the bulbs out. Nope! Have to get my car inspected tomorrow, so I am just going to give them the bulb and see if they can take care of it. I tried for over an hour.
  4. xerox6135
    xerox6135 Member
    170
    93
    michigan
    Just replaced mine took about 15 min. Remove coolant tank on passenger side it makes the job a little easier.
  5. Pandas Andpresents
    34
    Danbury, CT
    I was able to replace the passenger side marker and parking lights myself...without moving anything.
    It wasn't easy. I had my ratchet set out but didn't have the correct socket size and was worried that I wouldn't put everything back correctly.
    My hands are small and my fingers are relatively long. I was eventually able to untwist the bulbs out and I replaced them with LEDs.
    The cost of the bulbs was less than $2. The dealership charges $90 to replace them.
  6. Kevin Murray
    Kevin Murray New Member
    Austin, TX
    In case anyone is reading this looking for advice on how to get the right front marker (parking lamp) changed, most videos show moving the coolant tank out of the way. I still had trouble, until I found a video that pointed out I also had to unscrew the main headlamp socket, and move it and its harness a bit out of the way. Then I had enough space to be able to twist the marker light socket back in. I did it with the lamp lit, so I could see the light showing through the orange reflector cover, knowing I was in the right place. It still took trial and error to get tab orientation working. Finally a 1/4 clockwise twist made it solidly in place.
