Side of the road tire repair
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by sylvaing, Aug 27, 2023.
  1. sylvaing
    sylvaing Active Member
    1,028
    425
    Having no spare but a jack, tire plugs can be an option to repair a tire by the side of the road if the sidewall isn't affected. I find the pump and filler makes too much of a mess that needs to be cleaned at a cost.
    Project Farm tested four different tire plugs to see with one performed the best.
    I personally have a Dunaplug in my Model 3 and will add another one in my Prime.
    Blizzard_Persona likes this.
  2. BiomedO1
    BiomedO1 Senior Member
    1,446
    790
    SacTown, Ca
    I've used this; for decades. If you place the plug without rubber cement, there's a 50/50 chance you'll get a very slow leak. Never had a leak when spreading rubber cement on the plug, before inserting it. You can buy small replacement rubber cement tubes in the bicycle section of the store. Do Not buy the big tubes; it'll harden up before you get a chance to use it.
    Slime 11-Piece Deluxe Tire Plug Kit with Plug Bond - 2040-a - Walmart.com
    Hope this helps....
