Side undercarriage plastic cover falling down
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Mightyapprehensive, Feb 11, 2023.
  1. Mightyapprehensive
    Mightyapprehensive New Member
    Idaho Falls
    The undercarriage plastic on my 2013 Prius has fallen down. It is located on the front driver side behind the wheel. I unscrewed the part and found the part number (58297-47010) but don’t know if I need a new part as well as I can’t figure out how to attach the plastic shield piece to the screw. Any ideas?
  2. Mightyapprehensive
    Idaho Falls
    Here are the photos
  3. Mendel Leisk
    41,926
    Look at the first picture you posted, an extreme close up, one corner of “something” plastic under the car. Give responders a break, post more overall pics, explain orientation.
  4. Tombukt2
    Tombukt2 Senior Member
    13,461
    2,420
    Durham NC
    M8ne ate all 8n trash on 2 gen3 don't miss em . Most plastics under car gone no mpg is still same no changes .
  5. Mightyapprehensive
    Idaho Falls
    Sorry! I actually thought I had more photos posted. I’ve got a diagram one with the whole piece circled in yellow in relation to the car. The redline is the part that is off. And I’ve also attached other pictures from my car. It is on the driver side directly under the door. The front end of the piece (closer to the tires) is still attached. It is the back part of the piece that is no longer attached.
  6. PriusCamper
    PriusCamper Senior Member
    13,079
    5,306
    Pacific Northwest, USA
    Just get under there with a screwdriver gun and some screws and screw it back together by putting screws through the plastic and ignore the existing fasteners and holes.... I do it all the time. Don't bother with spending money on something new that you're never gonna see. Just fix it and forget it.
    mikey_t likes this.
  7. Mendel Leisk
    41,926
    It looks you’re on of it, with parts info. I’d score the fasteners that are missing (check, they may still be in place). If the panel holes are torn, but not too bad, fender washers may help; they have oversized OD’’s. Snipped off pieces of pipe hanger strap can work too.
  8. Tombukt2
    13,461
    2,420
    Durham NC
    I've got a set of four you can have might have the new fasteners too . I have to look
  9. mikey_t
    mikey_t Active Member
    371
    391
    Los Angeles
    That happened to mine too. I used gaffers tape to hold it until I could get zip ties. And then when I got an oil change the mechanic had some of the fasteners so he fixed it up.
  10. Mightyapprehensive
    Idaho Falls
    Thanks all for the suggestions. Hopefully I’ll be able to fix it up this weekend.
