Sigma 2006 EV switch kit-wrong ECU pin?
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Peter Senich, Jan 3, 2007.
  1. Peter Senich
    Peter Senich Junior Member
    22
    Duluth, MN
    I recently purchased the 2006 EV switch kit from Sigma and discovered that the supplied ECU pin won't insert in hole 27 of the H14 ECU plug. It has a projection that prevents this. Has anyone else encountered this problem?
  2. TheForce
    3,461
    537
    Wheelersburg, Ohio
    The little piece of metal that sticks up is there to prevent you from inserting the pin in the wrong wire harness. I had the same problem with mine. My solution was to use wire cutters to cut the little metal piece off. It then slipped in and locked into place.
  3. efusco
    efusco Moderator Emeritus
    19,891
    1,192
    Nixa, MO
    I don't know what's supplied. If you post a photo that would help. Did you lift the white bar on the plug to allow insertion?
    If all else fails you can get a pin from the steering column that will work.
  4. Peter Senich
    22
    Duluth, MN
    <div class='quotetop'>QUOTE(efusco @ Jan 3 2007, 09:24 PM) [snapback]370521[/snapback]</div>
    I did lift the white terminal retainer before I attempted this.
  5. Peter Senich
    22
    Duluth, MN
    <div class='quotetop'>QUOTE(theforce @ Jan 3 2007, 09:23 PM) [snapback]370519[/snapback]</div>
    Thanks. I'll give that a try.
  6. Peter Senich
    22
    Duluth, MN
    Would you please describe the correct orientation of the pin when inserting it in hole 27 and did you have to force it down with a jeweller's screwdriver? Would you please give me the pinout for the EV switch? I've found conflicting instructions for pin 2 and pin 3 (red and gray dimmer switch taps) Perhaps it makes no difference.
