Sigma Auto's OEM EV button for 06
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Kross, Apr 21, 2006.
  1. Kross
    Kross New Member
    88
    Pittsbugh, PA
    So, I am thinking about purchasing the OEM EV button for my '06 Prius from Sigma Automotive. I believe it is $57. Once I get that, will that be the only thing I will need to install it in the car and have the EV mode work correctly?
    Also, I did find different posts on PC as far as directions are concerned (Thanks Search function!), but my question is, would a Toyota dealership install it for me if I took it to them? I am a novice at best when it comes to working on cars, but am unsure if an actual Toyota dealership would be willing to install the part.
    Ideas, experiences... labor costs?
  2. Thomas Brock
    Thomas Brock New Member
    87
    I belive that the Sigma kit is all inclusive. I haven't purchased one, so take that with a grain of salt.
    As for dealerships installing the kit? That's something you'd have to ask your service manager...I've heard that some will and some won't.
  3. galaxee
    galaxee mostly benevolent
    9,810
    466
    MD
    you'll need some wires, some pins, a soldering kit, and a wire tap. and you'll need to pull some parts of the dash apart.
    afaik the pins that come with the 06 button are too large, we're putting together an 06 harness for one of our fellow PC members and will have to find out the correct pin size. when we do, we'll share the info. i don't know if Edward has found the right size pins yet or not.
    and for dealer install... honestly most of them have never heard of the EV switch and have no idea or interest. you might approach a tech and ask him if he's interested in a side job though :) many are receptive to that idea.
  4. 240sxer
    240sxer New Member
    154
    I wanted to order a EV button for my 06 but on Sigma's site they act like the buttons for the 04-06 are the same. I see no option to select that mine is an 06 which makes me think i'll be getting the wrong button. Anyone know what's up with that?
  5. TheForce
    3,461
    537
    Wheelersburg, Ohio
    Add the button to your order. When you check out there will be an option for comments. Tell them you need the 06 button.
