Significant amount of water spilled...
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by hybridmel, Jun 5, 2009.
  1. hybridmel
    hybridmel Junior Member
    36
    Okay, so this morning, I was driving with my big ol 44 oz cup of ice water, and bam, it spilled all over the front passenger side floorboard.
    I took the floormat and hung it over a railing, and did my best with paper towels to sop up the excess. There was a LOT of water, a pool of it sitting in the corner. Anytime I pressed down, water would bubble up from under the floorboard.
    I did the best I could, but I am worried that there may be damage to it......suggestions?
  2. EZW1
    EZW1 Active Member
    722
    81
    Phoenix, AZ
    2016 Prius v wagon
    Four Touring
    I would seriously removed the carpeting and let it dry out. If you don't mold and mildew will set in and you will be eternally displeased.
  3. richard schumacher
    7,664
    1,043
    United States
    Keep sopping. If you can stand it, and if the outside humidity iis fairly low, run the heat on high using outside air with the foot vents open; otherwise run the A/C on high with recirculation, again with the foot vents open. Park in a hot place with one or more windows partly open. Do not allow open containers of liquid inside the car.
  4. Sandy
    Sandy Hippi Chick
    860
    53
    Ocala,Fl
    LOL i make my son a pot of potato soup a large pot with milk, as i was getting in the pot spilled!!! this was in my BMW, needless to say i cleaned it and ended up trading it... you are lucky it was water.
  5. eaglesight333
    eaglesight333 Senior Member
    6,830
    79
    Northern, IL
    See if a friend has a small wet/dry vaccuum. Or a small hoover steam vaccuum. I have both, but mostly use the steam vac to clean car seats and floors. In anycase, try some type of wet vaccuum
