Significant and Sudden drop in milage (toyota aqua 2012)
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by Oic120, Jun 25, 2017.
  1. Mendel Leisk
    41,488
    Raising pressures has diminishing results beyond a certain point, but from 32 to 35 I think you'd see some improvement. In North America the regular Prius is 35/33 front/rear, if I recall correctly. Our has 17" which are maybe 33/32 (f/r) but I set them (all four) to around 35~36. It's not a lot of difference in ride quality, though 17" are more hard ride to begin with.
    Oic120 likes this.
  2. Oic120
    Oic120 Junior Member
    24
    Pakistan
    Thanks alot, I'll increase the pressure and share my experience with you.
    Meanwhile can you please tell me where is the port to connect a scanner in Aqua 2012?
  3. Sean Nelson
    Sean Nelson Active Member
    421
    182
    Vancouver, BC Canada
    Generally speaking, yes. Although the actual improvement may be in the "noise" and hard to notice.
  4. ztanos
    ztanos All-around Geek!
    3,339
    1,150
    40
    Cumming, Georgia
    It certainly wouldn't raise it 15 mpg(6.37 l/km).
  5. the47man
    the47man Junior Member
    Pakistan
    2013 Aqua
    The connector port is underneath your steering wheel just above you right leg. (Near the hood-release lever)
  6. Kingsway
    Kingsway Active Member
    114
    116
    Cambridge, UK
    2014 Prius c
    Active
    23 Km/l sound pretty incredible to me! I can only get that by driving at around 40 - 50 mph (64 - 80 Km/h) with a very light right foot!
