Featured Significant Avalon advances
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by bwilson4web, Jan 17, 2018.
  1. bwilson4web
    16,515
    Source: TNGA-based 2019 Toyota Avalon features new hybrid system - Green Car Congress
    Avalon Hybrid. A new TNGA 2.5-liter four-cylinder Dynamic Force Engine is more fuel efficient, runs cleaner, and is more powerful than previous iterations, and features enhanced thermal management. Technologies required include: Dual VVT-i with VVT-iE (Variable Valve Timing intelligent system by Electric motor); D-4S (Direct injection 4-stroke gasoline engine Superior version) direct injection and laser-clad valve seats; longer stroke (4.07 inches; bore remains at 3.44 inches) and high compression ratio (14:1); multi-hole direct fuel injectors; a variable cooling system; cooled Exhaust Gas Recirculation (EGR) system; and a full variable oil pump.
    Instead of oil pressure, its Dual VVT-i with VVT-iE variable valve system employs an electric motor to control variable valve timing, which aids fuel efficiency and promotes cleaner exhaust emissions (this is especially helpful in cold climates). The D-4S direct injection combines higher-pressure direct fuel injection (DI) and lower-pressure port fuel injection (PFI), and applies each method of injection based on specific driving parameters. Furthering fuel efficiency are new multi-hole nozzle direct injectors (six holes per injector).
    The four-cylinder Dynamic Force Engine is married to an all-new Toyota Hybrid System II powertrain that’s been engineered to inspire both spirited driving and fuel consciousness. THS II uses two electric motors—MG1 and MG2—to supplement the charging of the hybrid system’s Nickel-Metal Hydride (Ni-MH) battery pack, while MG2 assists the engine.
    Bigger and more comfortable suspension too.
  2. Trollbait
    12,812
    Is there any actual differences in the hybrid drive train between the Camry and Avalon?
  3. bwilson4web
    16,515
    The article doesn't mention the Camry so I don't know.
  4. Trollbait
    12,812
    Sounds like the same hybrid system(the engine is the same) as in the Camry, so it is more new to the Avalon.
    With the growth spurt, it will face competition from the Accord.
  5. austingreen
    austingreen Senior Member
    13,713
    4,231
    Austin, TX, USA
    The engine as described sounds exactly like the camry engine ;-) well except for one big quibble, it has a little wrong information.
    Battery, motors, controller, psd - who knows, my guess is they are the same. If I were designing it for avalon, rav4, and lexus es duty I'd keep the psd and mg1 the same but I might use a slightly more powerful lithium battery and mg2 as these are heavier vehicles and better accelerator response might be worth it.
    LasVegasaurusRex likes this.
  6. LasVegasaurusRex
    LasVegasaurusRex Active Member
    234
    110
    Las Vegas, NV
    Safe bet. Not sure if it's just my imagination or what but I feel like the Avalon and ES are exclusively made for people over the age of 60.
    It's a shame too because the ES was my dream car back in like 1995. But I haven't been a fan of it since the switch to Avalon platform in 2012, maybe even before then. Something about the newer ones feels "off" but I can't put my finger on it.
  7. mikefocke
    4,073
    1,858
    Sanford, NC
    Hey, us old guys buy cars and help keep the company healthy. My wife has a '11 Avalon and loves it. It was the car with the most US content when we bought it. 84%. I like it except for its MPG and it had a little too much HP (gasp).
    LasVegasaurusRex and bisco like this.
  8. bisco
    52,800
    avalon hybrid is a pretty sweet cruiser, and you can get a senior citizen discount.:cool:
  9. Mark57
    2,945
    2,740
    OK
    Sooo, Avalons attract all the hot chicks . . .;)
    #9 Mark57, Jan 20, 2018
    LasVegasaurusRex and Raytheeagle like this.
  10. bwilson4web
    16,515
    Wrong weed.
