Significant Drop in Gas Mileage
Discussion in 'Prius v Fuel Economy' started by Hello123, Mar 4, 2018.
  1. Sam Spade
    Sam Spade Senior Member
    2,036
    1,024
    2017 Prius c
    You don't KNOW that for sure.
    All you really know is that you are going to the same station and using the same pump(s).
  2. Mendel Leisk
    42,325
    IIRC, the Prius v has a small drum brake incorporated in the rear disk brake, for parking brake. That would eliminate one potential brake drag issue (the regular 3rd gen Prius with it's parking brake incorporated into the disk brake, prone to drag if misassembled) .
    But yeah, just for giggles: chock the front wheels, raise the rear, release the parking brake, and make sure both rear wheels spin semi-freely. This is "low-hanging fruit", something that can be done relatively easily, and a variable that should be checked, even if it's just to be dismissed.
    #22 Mendel Leisk, Mar 4, 2018
    Montgomery likes this.
  3. Hello123
    Hello123 New Member
    Markham
    I appreciate you help. My husband agrees slowing down would decrease the gas use. It just does not explain why the gas usage got worse from 4.5L/100 Km to 6.3 L/100Km. My husband leaves for work everyday at 4:30 am. He arrives at work at 5:15 am, fifteen minutes before his shift starts. He is like clock work. He drives the same 52 km at approximately the same speed 100 Km/hour (60 mph) every day. When we drive together on the weekend I always ask my husband to turn up the heat. Since he is the main driver commuting to and from work he keeps the car temperature cool as he has on all his winter gear and does not take it off for the drive to work....hat and gloves included. We have had the discussion with Toyota about tire pressure and they did not recommend changing the air pressure outside of the manufactures recommended tire pressure window. My husband has a work shop in the garage and the car is parked in there all year round. The garage is heated and kept about 60 to 65 F. My husband does not see the benefit of purchasing a heater block for our Prius V. I was just wondering if the drastic rise in fuel usage is the an oddity for a 2012 prius V? or has anyone else had the same issue? Were you able to fix the issue and get back to 4.5L/100 Km?
  4. Mendel Leisk
    42,325
    If it get's back to displayed high 4's in summer, I would write it off as seasonal variations, and acceptable. If not, then I'd start digging.
    BTW, your displayed very likely is a little worse (lower) than calculated. Toyota is notorious for exaggerating the display, anywhere between 3 and 10 percent, depending on the vehicle. Our 3rd gen Prius has displayed fuel economy 7.5 percent optimistic, with well over 100 calculated tanks.
    I think what you need is for more Torontonian Prius v owners to chime in, regarding their winter mpg. I suspect it's not far out of line, but not sure. Have a look at this, the median fuel economy (calculated) being reported by other owners, and this is all over the map, not in a cold winter clime like Toronto.
    Very few are getting 4.5, judging from Fuelly:
    Toyota Prius V MPG - Actual MPG from 890 Toyota Prius V owners
    A screen grab from above:
    #24 Mendel Leisk, Mar 4, 2018
    Raytheeagle likes this.
  5. Hello123
    Hello123 New Member
    Markham
    We don't touch our brakes. Our Toyota dealership looks after our brakes and has done so since we owned the car which we purchased band new. The gas mileage dropped after a year and half of running wonderfully. We just can't get back to the 4.5L/100 Km. The car for the last four years has consistently got 6.3 l/100 Km. Not very good my husband constantly tells me. I have to listen to my husband complain about the terrible gas mileage we get now on our Prius V. Is anyone else having this issue?
  6. fuzzy1
    10,703
    Here is a troubleshooting list of MPG killers, covering almost all the usual suspects except sticking brake pads/pistons/calipers:
    Fuel economy complaints/queries? Please copy, paste & answer these questions, esp. if you're new | PriusChat
    Please review it to see if any topics have been missed.
    Fresh new tires will typically increase fuel consumption a bit until they are broken in.
    Driving & skiing in BC and Alberta the past two weeks, I noticed that fuel stations had different patterns of ethanol vs octane rating. Some stations were labeled as having 10% ethanol in all grades, while others were labeled for 10% in #87, 5% in #89, and 0% in #91. So if your supplier has recently changed patterns and the 91 Octane shifted from 0% to 10%, this would be expected to change your fuel consumption, though only by a few percent.
    I would not blindly trust them to catch brake pads that have started to drag or calipers that have frozen from corrosion, especially if you live in an area where road crews love to use salt or brine in the winter. This has now caused me problems on two past cars, as local government policy forced increased salt use and auto mechanics had not yet caught up.
    #26 fuzzy1, Mar 4, 2018
  7. Hello123
    Hello123 New Member
    Markham
    Thank you for the chart. I will share it with my husband when he comes home.
    We would be thrilled if we got 4.5 L/100 Km in the summer but we get around 6 L/100 Km in the summer. Winter we get 6.3 L/100 Km.
    Thanks again for the chart.
  8. Prodigyplace
    12,712
    11,848
    Central Virginia
    Stop & go from traffic lights affect mileage too, especially at higher speed intersections.. I assume your husband is traveling toward Metropolitan Toronto.
  9. Mendel Leisk
    42,325
    You don't have to mess with them, but as I said, just raising the rear of the vehicle, releasing the parking brake, and spinning the wheel, is low hanging fruit.
    Even simpler: directly after an extended drive, feel each wheel. If any are inordinately hot, that would likely be due to brake drag.
    As likely as not your problem (if any) is not brake drag, but if you're semi-serious, it's an easily checked variable.
    For me the elephant in the room is that Fuelly chart. I'm not sure you can filter it to be Torontonians only, though there likely are a few. The majority I would think are from the States, and likely with milder winters. Again, these are calculated tanks. It could be a few fluke good tanks at the outset? Because if you look at the median in the chart, you're in the middle of the pack.
    fuzzy1 likes this.
  10. Hello123
    Hello123 New Member
    Markham
    Our Toyota dealership is excellent. They recommend just what you are saying to have the caliper cleaned and in working order a few time a year because of the salt we use on our roads. Our brakes are tip top thanks to our Toyota dealership. My husband is like clock work he always fills up at the same gas station on the same day on his way home from work. He loves his aeroplan points!
  11. Hello123
    Hello123 New Member
    Markham
    When my husband leaves the house at 4:30 am every day. He says there is not many cars on the road at 4:30 am. He has a short drive to the 404 then on to the 401 for his travel to work. It is almost all highway well before any rush ours. He told me the low 6.3 L/ 100 Km is not due to stop and go traffic as he has virtually none.
  12. Hello123
    Hello123 New Member
    Markham
    My husband just came home. I asked him if he would check the wheels by giving them a feel. He gave me a dirty look and said he pays Toyota to look after his brakes and has complete confidence in them. When he get up from his nap I will tell him about the chart. I best turn off the computer so I can get dinner started.
  13. Mendel Leisk
    42,325
    Another thought: is it still on the original 12 volt battery? They're good for 4~5 years, and might be a factor, though a long shot. A dying battery may make the engine run more.
    Kaptainkid1 likes this.
  14. fuzzy1
    10,703
    He has a lot more confidence in the dealership than I've ever had in even my best independent shops.
    If he won't check, them you can check this yourself within a few minutes after he gets home some day.
  15. Mendel Leisk
    42,325
    With sustained higher speed driving, the engine won't do any shut down. If you check the stats, the car does better around town then on the highway:
    Fuel consumption ratings search tool - conventional vehicles | Natural Resources Canada
    Snapshot from above:
    The threshold for engine turning off is around 72~74 kms per hour, fwiw. And that is instrumental in achieving the better numbers. Around town the car shines, especially if you abide by speed limits, keep a good following distance, coast up to slow downs, and so on.
    This is at odds with the current canadian fuel consumption stats (snapshot above). I know they've changed the testing method in the last few years, to bring it closer to reality. And even then, those are in ideal conditions. Fuelly stats are the reality for the car.
  16. Montgomery
    Montgomery Senior Member
    2,254
    2,242
    Orange County, CA
    I work only 3 miles from my house. During the winter, this barely gets the engine warmed up. Mileage is 8 miles per gallon less (40mpg) than when I jump on the freeway to someplace. Then it soars up to 50mpg!
  17. Prodigyplace
    12,712
    11,848
    Central Virginia
    I think that is why my salesman with his Gen 1 Prius walks to work at times. I believe he said his commute is about 1 mile.
  18. Mendel Leisk
    42,325
    OP has long commute, but also sustained high speed 100~110 km/hr. And it's a Prius v.
    I'm trying my durndest with our regular Prius (albeit with 17" rims, a real mix of trip lengths), and my fuelly icon's at 4.9 liters/100 km. OP wants a Prius v to return to sub 5, in TO, in winter...
    fuzzy1 likes this.
  19. mikefocke
    4,077
    1,861
    Sanford, NC
    A confession.
    I too have a '12 v.
    In the beginning, I was getting MPG better than I am now. Only by 3%. Why? Because the long miles trips I took back then I was obsessive about doing 4-5 MPH under the speed limit. Gradually, I got less obsessed. Today's trip to the grandkids I left a bit late and did 1 or 2 MPH over the speed limit. Slower than 95% of the huge things that were passing me but enough to affect my MPG. So my average has slumped. Even though my tires are pumped harder than they were and there are no other changes.
    Just the habits of the driver critter.
    I track my MPG using fuelly so I can see seasonal or equipment changes. I still get EPA figures on average, just not as robust.
    (Checked the air filter lately? Still running the HVAC on Auto? Looked at the degree days for the affected period? Still using ECO mode? Any change in cruise control use? )
  20. Prodigyplace
    12,712
    11,848
    Central Virginia
    My son was hoping his 2015 Prius v would get about the same mileage as the 2005 Prius he had earlier. I think the Prius v ended up being a little lower.
