Signs my battery may be going
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by tylerjames, Dec 10, 2015.
  1. tylerjames
    tylerjames Junior Member
    26
    north bay
    Hello everyone, had a question. My car seems to kick the engine on no matter what the battery is charged to everytime I turn my car on. Is this normal? I thought it was to work off the battery unless speed or heavy battery use was happening. I read somewhere this could be a sign the battery is going
    Also, its a 2007 Prius with 112k. I get about 300 miles out of a tank (I always fill up when 2 pips are left.) My driving is 60 city 40 hwy. Is this about right? seems to be 40-41 MPG
    Thanks
    52,888
    welcome! it's possible. did you just buy it? if you are talking only about when you start the car, that is normal. it has to warm the engine for pollution control. when it is at proper temp, you can do some low speed driving if the battery has enough charge.
    best to watch your mpg's by measuring every time you fill up. all the best!(y)
  3. JC91006
    16,938
    8,647
    Seems normal, the engine always turns on when you first start it
  4. tylerjames
    26
    north bay
    Thanks everyone, I figured it was normal but just wanted to double check.
  5. wjtracy
    wjtracy Senior Member
    11,374
    3,609
    Northern VA (NoVA)
    Where are you Tyler, Maryland?
    If it goes bad you want to check back here for how to ask for help from Toyota.
    MD is CARB 10-yr 150k miles but your car is before 2011 when MD joined CARB but I still think that MD is CARB helps.
  6. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    Prius designed to heat up engine for emissions efficiency. So turning on rapidly on start up is normal.
    You can choose to fill up any time you wish, but if you are consistent at two pips, pay attention to how many gallons you are filling with and divide into total miles you drove and that will give your real MPG.
    300 miles with two pips left doesn't seem abnormal.
  7. johnnyb588
    johnnyb588 Member
    193
    73
    Tempe, AZ
    I
    40 hwy seems a *little* low, but that depends on a number of factors (grade, speed, tires, weather, altitude, etc.). 60 city is pretty good (also depends on a number of factors), so I'd say that number indicates you're doing ok.
    If you're really worried about it, you can always hook up a techstream, do some tests and pull data to analyze. The thread below has an excellent writeup of how to analyze battery health and how a grid charge seemed to improve the state of health of the battery quite a bit.
    Quantitative Results of Grid Charge/Discharge | PriusChat
    Side note, does anyone know how people hyperlink threads with the thread title rather than the URL?
    Edit: I just realized that PC changed the text of the hyperlink after I posted it. That's nifty.
  8. dhancock
    dhancock 2 Prius Family
    357
    40
    Hamburg, NY (Buffalo area)
    Folks in warm climates may not realize the impact of cold weather climates:
    • Cold weather reduces the efficiency of batteries
    • The engine needs to warm up (mentioned earlier)
    • Many cold weather states mandate a "winter" fuel mix, which has lower energy content than "summer" fuel mix.
