"Simple" Intelligent Parking Assist?
Discussion in 'Gen 4 Prius Main Forum' started by LilyT, Nov 25, 2017.
  1. LilyT
    LilyT Junior Member
    Seattle WA
    2018 Prius
    Hi there, I'm doing research trying to decide which Prius to buy. I like the Intelligent Parking Assist (IPA) feature. However, in this famous Visual Tables of Gen4 Package Combinations article, it is referred as "Simple IPA". The word "Simple" keeps me wondering if there exists another "Advanced" version of IPA? Are all the IPA installed on different Prius models the same version?
    Thanks a lot!
  2. Tideland Prius
    16,683
    No "simple" just means it's easy to use - just follow the onscreen instructions. IPA is also known as "Advanced Parking Guidance System" or APGS if that makes you feel better :D
    The 3rd Gen Prius, Prius v and Gen 4 Prius will have different IPAs. The one in the Gen 4 Prius (2016-now) is the latest one.
    On the current Prius, it will...
    • in a back-in mode, steer the car out then back into the spot (while the old version, you had to steer the car out then it will start the auto-parking)
    • In both parallel and back-in mode, ask you to shift into R and/or D as necessary to get the car centred in the spot
    • assist in pulling you out of a parallel parking spot (exit assist mode)
    Kay1000RR and RCO like this.
  3. LilyT
    LilyT Junior Member
    Seattle WA
    2018 Prius
    Thanks for the clarification, which is very helpful!
    RCO likes this.
  4. Tideland Prius
    16,683
    You're welcome.
