Simple stereo amp power connection?
Discussion in 'Gen 3 Prius Audio and Electronics' started by BirdMan3, Mar 29, 2020.
  1. BirdMan3
    BirdMan3 New Member
    Madison, WI
    What's the best power connection technique for a aftermarket amp going into a 2011 Prius?
    I'm doing head unit, all speakers, and amp.
    Also, pull the main 12v power before starting, right?
    Thanks All!
  2. Leadfoot J. McCoalroller
    8,291
    7,808
    Pennsylvania
    2018 Prius c
    Assuming that the amp will be in the rear half of the car, I would lay in a wire sized for the demand back towards the 12v battery at the back of the car, and connect it to an in-line fuse holder hooked up to the shunt side of the + connector on the battery.
    Yes, disconnect the 12v power during your work.
  3. BirdMan3
    BirdMan3 New Member
    Madison, WI
    Perfect. I thought it was that simple but unsure of the connection point. Thant helps me a ton!
    Yes, amp is going in the back so I'll do a short link to the battery and keep the ground as short as possible.
    Thank you!
  4. Leadfoot J. McCoalroller
    8,291
    7,808
    Pennsylvania
    2018 Prius c
    Should not be hard. You always put your fuse holder as close to the source (battery) as possible, and if you connect it to the shunt side instead of the battery side then the draw of the amp will be 'noticed' by the DC/DC converter and factored into the charge cycle for the 12v.
  5. BirdMan3
    BirdMan3 New Member
    Madison, WI
    I'm sorry that I'm not exactly clear. I'm very handy but not up to speed on the Prius.
    So I hear you, don't connect the amp power cable (yes I have a proper sized Alpine amp cable w / inline fuse) to the starting battery.
    This is where I'm clueless. So do I follow the positive battery cable from the starting battery and I will find a connection point between the Toyota e-car battery and the starting battery? It's kind of buried but I hear you about integrating it into the the charging system. It's a 2011 and if I just dig will I find it?
    Thanks and sorry for the hassle. Also I can find a stero wiring diagram anywhere. Need to sort out two of the four plugs from the factory stereo.
    Thanks!
  6. BirdMan3
    BirdMan3 New Member
    Madison, WI
    ROGER- Sorry for the previous note. I got it. There is only the accessory terminal post off the positive of the starter battery. There's nothing else there so I guess that's what you meant. Sorry. Also, I'll just buy and download the Toyota diagram. THX!
  7. skorpyo33
    skorpyo33 Junior Member
    30
    Sebastian, FL.
  8. skorpyo33
    30
    Sebastian, FL.
    Wish you had a pic of this shunt side for battery. Cause im trying to figure out where to hook up inline power.
  9. Leadfoot J. McCoalroller
    8,291
    7,808
    Pennsylvania
    2018 Prius c
    Post a picture of yours, I'll try to steer you
  10. skorpyo33
    30
    Sebastian, FL.
    I got it, theres one bolt facing up right to the left of terminal connector under red flap.
  11. skorpyo33
    30
    Sebastian, FL.
    How about a vid instead of a pic @2:54 on youtube: Prius high voltage battery repair | gen 3 by JUST VLAD
  12. skorpyo33
    30
    Sebastian, FL.
    Heres the pic.
  13. Leadfoot J. McCoalroller
    8,291
    7,808
    Pennsylvania
    2018 Prius c
    Yep, I would use that forward-facing terminal. I know there's a protection fuse between that and the battery clamp, and at least some models of Prius also have a sense shunt there to make certain that the DC/DC converter is driving enough output to recoup all losses and maintain 12v charge.
    skorpyo33 likes this.
  14. skorpyo33
    30
    Sebastian, FL.
    Done, ty. Put it right in that spot too. Now for the calibration nightmare.
    ASRDogman likes this.
