Single beep opening driver's door
Discussion in 'Gen 3 Prius Main Forum' started by edstewbob, Jul 24, 2010.
Thread Status:
Not open for further replies.
  1. edstewbob
    edstewbob Junior Member
    Greenville, SC
    About 3 weeks ago our Gen III (Prius III with Nav and Solar) began generating a single standard duration (maybe 1 second, similar duration to reverse beep) beep each time the driver's door is opened. It only occurs with the driver's door and happens whether the car is locked, unlocked, started or not. We had our reverse beep-beep converted to a single beep about 2 months ago and now this single beep is annoying each time we open the driver's door whether we are inside our outside of the car. I can't find any information on Priuschat or elsewhere on this and my dealer so far has been no help, although I have not taken it to have repair look at it. We are concerned that there is something wrong and don't know what else to look for. We could not find anything in the user manual that described why this beep would continue occurring.
  2. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    By any chance you have the 2nd FOB stored in the car? Also, look at the dash to see what the error message (if any) is being displayed when you get the beep.
  3. jorbock
    jorbock New Member
    Longmont, CO
    The car will make that extra beep when the driver's door is unlocked if the sunroof is open. I guess it's to remind you that it's open.
    3 people like this.
  4. edstewbob
    Greenville, SC
    The sunroof was apparently open a little bit even though we could not see that. I opened and closed it and the beep went away. Thanks a bunch.
Thread Status:
