Single DIN Head Unit upgrade and Scangauge II combo
Discussion in 'Gen 3 Prius Audio and Electronics' started by yyyiiikes, Aug 12, 2012.
  1. yyyiiikes
    yyyiiikes Junior Member
    84
    Austin, TX
    Here's something a little different… Single DIN HU upgrade with Scangauge II installation.
    I would like to extend thanks to Spiderman, XS650, and Frodoz737 for all HU the picture tutorials and advice.
    Gear Used:
    Alpine IDA-X305S Head​
    Scosche Dash Kit TA2105B​
    Alpine KTP-445 Power Pack​
    Alpine TU-550hd radio tuner​
    Metra Axxess ASWC​
    Metra Toyota Axxess harness #70-8114​
    Panel Mount USB​
    Scangauge II​
    Before:
    After:
    USB interface located in the upper glove box (thanks Frodoz737 for the idea)
    Scan Gauge II mounting:
    Foam core made using tools from one of my other hobbies:
    Hollowed out with balsa and felt sheeting:
    Bezel
    A cutout was made using the outline of the Scangauge. Then it was sanded, covered in a black vinyl decal, and installed.
    R-P likes this.
  2. LulzChicken
    LulzChicken Prius Enthusiast
    791
    135
    Alabama
    This looks really nice! I upgraded my head unit to a single din as well and was thinking that I'd put a Scangauge in the lower din slot if I bought one.
  3. gliderman
    gliderman Active Member
    751
    223
    Do you steering wheel controls work with these head units? Sorry if this is a dumb question but I am not much on audio tech. Thanks!
  4. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Well done.
  5. LulzChicken
    791
    135
    Alabama
    I know this isn't a very detailed response, but you do. However, there are plenty of kits and harnesses that you can buy to re-enable the steering wheel controls. I have a friend who did that and it's common for people to want to keep their steering wheel controls. I'm not too certain of the specifics though.
  6. yyyiiikes
    84
    Austin, TX
    If you purchase a SWI (Steering Wheel Interface) kit then your steering wheel buttons can control the aftermarket head unit. There are a couple of different solutions out there - I went with the Metra device and also purchased the Toyota harness. This was really simple.
    Here is a picture of the gear installed. The SWI is the small box in the lower left and the Toyota harness is also shown. This plugs directly into the factory wiring and when first turned on, the unit will detect the vehicle it is connected to and automatically configures itself. Could not be any easier.
    LulzChicken likes this.
  7. kelvin johnson
    kelvin johnson New Member
    portland
    Can I install Kenwood KMM-BT525HD for HD radio in Prius II(no JBL)? Does it work?
