Siphon gas out.
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Alen Kalati, Oct 20, 2017.
  1. Alen Kalati
    Alen Kalati Junior Member
    32
    Hi all.
    sometimes wife is filling the tank up, and I end up not using it for months. Is there a way to siphon gas out and put it in my other regular Prius?
    Thanks,
    Tracksyde likes this.
  2. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,095
    Columbia, SC
    Did you want to do this merely because you're worried about the gas becoming old and causing drivability problems?
    If so, I'm not sure that is really a problem any longer with fuels. My wife recently inherited a vehicle that sat unused for about 18 months. I installed a new battery and it fired right up. My wife's friend stored a PT Cruiser at our house for even longer. Same thing, it never was started from the day she dropped it off. Installed a new battery and it fired right up.
  3. Alen Kalati
    32
    Thanks for your reply. No, not issues like the car won't turn on - more like it affecting performance / gunk buildup etc.
    Also, in some situations instead of going to fill up the other car (Or the lawnmower) it would be easy to just siphon a few gallons out of the pip. But I'm not sure if it can be done...
    52,863
    your fine for at least 6 months. ask your wife not to add any gas.
  5. jfschultz
    jfschultz Active Member
    639
    115
    Germantown, TN
    2020 Prius Prime
    While I am more comfortable with filling up about every three months, the manual does say to go through at least half a tank every six months.
  6. Mendel Leisk
    42,355
    I think modern gas tank filler necks are VERY well protected against siphoning. I would take the path of least resistance: just use the gas. Regardless of the temptation to keep engine use to absolute mininum, maybe intentionally avoid charging the car sometimes, enough to run through a tank every couple of months? Probably good for the engine to avoid long stretches without use.
  7. bisco
    52,863
    mendel, that's heresy!:eek:
    jerrymildred and Mendel Leisk like this.
  8. jerrymildred
    jerrymildred Senior Member
    11,517
    14,170
    Tampa, FL
    Whoah! Flashback to another thread. :D
    bisco and Mendel Leisk like this.
  9. ericbecky
    ericbecky Hybrid Battery Hero
    4,452
    3,359
    Madison, Wisconsin
    You will not be able to siphon.
    There is a way to get out the fuel but it is not a simple task. I would avoid doing it if possible.
    Disconnect fuel line under the hood and attach a rubber hose. WARNING. Fuel line is pressurized at 42psi.
    This can be messy and dangerous if you are not careful. Wear safety equipment. Protect your eyes and face. Do it when the engine and exhaust is cold.
    Energize the fuel tank pump and pump it out.
    I've had to do this with various customer cars over the years. Latest one was a Prius that got filled with diesel fuel.
  10. wjtracy
    wjtracy Senior Member
    11,374
    3,609
    Northern VA (NoVA)
    As above, very hard to siphon these days. You could use Stabil or something
    WilDavis likes this.
  11. Mendel Leisk
    42,355
    Hear all the disclaimers?
    In other words, done for good reason. Operative phrase: "had to do this".
    For any more trivial reason, say maintaining your high Fuelly status, fugedaboutit: use it.
  12. ericbecky
    4,452
    3,359
    Madison, Wisconsin
    Usual reason I have to do this is for cars that have been sitting unused for a long time ... as in 2 or 3 years.
  13. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    For the PiP, the cost of Stabil plus gas is likely going to exceed electricity. I would echo others and suggest using the gas by pressing the HV button.
  14. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    For quite a while now, I am filling about half tank only.
    Side benefit: saving about 20-22 lb of dead-weight...
  15. El Dobro
    El Dobro A Member
    7,106
    3,282
    The PiP tank is pressurized to prolong the life of the gas. That's why you push the button and wait 'til the car says it's ok to fill.
  16. jerrymildred
    11,517
    14,170
    Tampa, FL
    Which, on my car, happens faster than I can release the button. :D
