Siren going off at night randomly (after service)
Discussion in 'Gen 3 Prius Technical Discussion' started by MegaPrius101, Aug 5, 2019.
  1. MegaPrius101
    MegaPrius101 Junior Member
    57
    31
    I
    so I dropped my car off at the dealer a few days ago for a brake fluid flush (that’s it).. I get the car back and do my rideshare driving for hours.. get back home around 11:30pm and 2 hours later the siren is going off by itself in garage..
    I go into garage and check things out and hit the siren button on my remote to shut it off.. I was standing around for about 5 minutes until I left and as I left garage , it went off again by itself.. so I unplugged negative terminal on battery so I could sleep..
    Long story short, even after alarm is reset after unplugging the battery several times over night , it’s still reoccuring..
    I just left the car at the dealer for 4 hours so they could see if problem happened again but it didn’t..
    I do want to note that I just drove the car 10 minutes to the dealer and not several hours ( problem did not reoccur )..
    So my question is, what could this be?
    My plan is to keep battery untouched tonight when I get home and if siren goes off tonight again, I will drive car early tomorrow morning for a few hours and bring it to dealer around 1pm and let it sit for a few hours to see if it reoccurs.
  2. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Thats it? Only flush, & no refill?! :eek:
  3. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    My first guess is
    A-- You have the original 12 volt battery
    B--When they 'serviced" your car they leave all the doors open and it killed your 9 year old 12 volt battery now its borderline. Get a dc voltmeter find the front jump point under the hood measure the 12 volt battery voltage with the car off. Write that down.
    Then with car still off turn on the headlights and measure the 12 volt dc voltage again.
    Post those numbers back here. My guess is the 12 volt battery is tanking with the headlight load.
  4. MegaPrius101
    57
    31
    I
    I know it seems ridiculous for the electronics to act up after a brake fluid flush..kind of like blaming the tire shop for engine issues.. but it was weird how it started same night as repair..
    Well at least problem didn’t reoccur last night after leaving battery hooked up..
    Hopefully doesnt return..wonder what it was..service advisor at my dealership was saying he’s never seen that..
  5. bisco
    52,820
    as ed mentioned above, how old is the 12v?
  6. MegaPrius101
    57
    31
    I
    I just put in a brand new Optima yellowtop a few weeks ago... no issues with electronics since then, except this (in fact I think my car runs better with Optima) ..but not sure if it’s battery..
  7. edthefox5
    10,096
    4,837
    Clearwater, Florida
    Do my test in post #3
