Siri eyes free
Discussion in 'Prime Audio, Electronics, and Infotainment' started by bodgm, Jun 4, 2017.
  1. bodgm
    bodgm Junior Member
    58
    US
    Is this a function in the Prius Prime? If it is, does anyone use it? Is it worth getting and iPhone? I'm assuming the new Google Assistant with my Android can't work? Why is there a Qi charger compatable with an IPhone?
  2. jerrymildred
    jerrymildred Senior Member
    11,517
    14,164
    Tampa, FL
    I had to think about that title for a while. Do you mean Siri Hands Free?
  3. bodgm
    bodgm Junior Member
    58
    US
  4. alexcue
    alexcue Active Member
    346
    311
    So Cal
    It works well, it isn't super fast but I can hear a message if I need to and respond to it. Only needing to push one button for a few seconds.
    mr88cet likes this.
  5. jerrymildred
    11,517
    14,164
    Tampa, FL
    My iPhone connects to my PiP via bluetooth and, if I want to make a hands free call, I just press and hold the home button for a few seconds till Siri comes on and say call so-and-so. Or "send a text to ..." and dictate the text. If I'm not mistaken, I can do the same with the phone controls on the steering wheel.
    I assume the Prime is even more competent.
  6. Riversong
    Riversong Junior Member
    28
    48
    Amsterdam NY
    Siri eyes free works pretty well in a Prime. Also you can buy Qi charger cases for the iPhone.
    jerrymildred likes this.
  7. 'LectroFuel
    'LectroFuel Senior Member
    880
    673
    San Juan Capistrano, CA
    Anything is worth getting an iPhone for! I strongly doubt Google will work with it. There are compatible charging cases that are built for iPhone. You hold the phone pick-up button for a few seconds to use siri, which I find works better than built-in car voice commands.
  8. jerrymildred
    11,517
    14,164
    Tampa, FL
    Yup! Works great.
  9. mr88cet
    mr88cet Senior Member
    2,313
    1,335
    Austin, TX
    One button... on the iPhone, or on the P.Prime?
  10. Tideland Prius
    16,634
    Prime. (Well press and hold)
  11. mercat68
    mercat68 Active Member
    311
    216
    Mount Airy, MD
  12. mr88cet
    2,313
    1,335
    Austin, TX
    So then, which button on the P.Prime?
    I think I recall that "hey Siri" worked while plugged in through USB.
    iPhone ? Pro
  13. mercat68
    311
    216
    Mount Airy, MD
    The phone off-hook button:
    blueterp, Tideland Prius and mr88cet like this.
  14. davidgro
    davidgro Junior Member
    Western WA, USA
    2018 Prius Prime
    Dang. Holding that button very much doesn't trigger Google Assistant on my Android phone. (Nor do any of the others in that cluster)
    I guess I'm just stuck yelling at the thing half a dozen times each time I want its attention when there is road/weather noise? Are there any better options?
  15. schja01
    schja01 Senior Member
    1,858
    1,229
    Chicagoland
    2024 Prius
    Limited AWD-e
    I like sending or replying to a message by saying:
    Tell “contact name” message
    Works well.
