Skid Control Component Pricing Help
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by geocarr, Jun 6, 2016.
  1. geocarr
    geocarr New Member
    Faison, NC
    My dealership just called and said my 2007 Prius with 155,000 miles needs a skid control component for $1,600 and a right front speed sensor for $240 but feels very certain this will fix the car. Does anyone know where I can get a cheaper but reliable skid control component?
    The dealership also said my main battery will probably die after about 50,000 more miles or more and costs $3,000 to replace and install.
    The original problem:
    I would drive the car about 30 miles or more and then warning lights ((!)) and VSC would come on. About 10 miles later, the car would max out at 38 MPH and the main battery gauge on the display would turn purple. After 3-6 more miles, the main battery gauge would drop to one bar and the transmission would only go from Park to Neutral. I turned the car off for about 20 minutes and it restarted and ran just fine for a while and then the problem reoccurred. I took it to the dealership.
    Thanks for any help, advice, and suggestions.
    - George
  2. JC91006
    16,831
    8,603
    The skid control ecu is about $35 on eBay
  3. geocarr
    geocarr New Member
    Faison, NC
    I called the dealership back to clarify and they said I need the skid control computer, part # 89540-47130. I did a google serach and didn't see one that exactly matched the last 3 digits of that part number. Opinions and experience anyone?
  4. Patrick Wong
    18,210
    6,514
    Do you prefer to pay $1,600 for a new skid control ECU or do you want to try a used unit?
    Here is just one example of a used unit sold on eBay for $50:
    2006 2009 Toyota Prius Skid Control ECU Module Computer Unit ECM 89540 47100 | eBay
  5. andrewclaus
    andrewclaus Active Member
    993
    326
    Golden, CO
    Plug your VIN into this site and see what part number comes up. The skid control computer is item 89540 on the diagram.
    Also, see if you can get the diagnostic test codes (DTCs) from the dealer and post them here. If there's any indication in the DTCs about the hybrid battery, it would be good to know and may affect your decision.
  6. JC91006
    16,831
    8,603
    I have a 2008 skid control ecu unit, if you wanna try it, just send me a PM. I just have to remove it from the car
