Skirts over back wheels
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Thagg, Sep 18, 2004.
  1. tomdeimos
    tomdeimos New Member
    995
    Lexington, MA
    I just saw an Insight with the two color black and car color skirts. Looked great!
  2. jdjeep98
    jdjeep98 New Member
    211
    Wilmington, DE
    Throw in the racing disk wheel covers and I'll take one, too! B)
  3. OverTork
    OverTork Junior Member
    68
    Northville, MI
    I have a question for someone who has the screw in racing disk wheel covers. Does it look like it would be difficult to attach them to the factory snap on rings?
    I really don't want to have to carry tools to check and adjust tire pressure, I do it too often.
  4. flareak
    flareak Fleet Captain
    1,016
    St Louis, MO
    skirts.... *vomits*
  5. darelldd
    6,059
    389
    Northern CA
    Prius.... *vomits*
    I think the skirts can save it!
  6. bshef
    bshef Active Member
    510
    76
    OC So. Calif.
    with the racing Disk.......don't u need different Wheels? or will the somehow fit over the stock rims?
  7. flareak
    1,016
    St Louis, MO
    lol the Prius isnt that bad. I think the rear end needs fixing, but I dont think it's worse than say... a PT cruiser or SSR
  8. Bob Allen
    Bob Allen Captainbaba
    1,273
    Seattle, WA
    I saw an Insight at an alternative fuel fair that had its side view mirrors removed and replaced with a TV screen. The driver is a pilot as am I, and I asked him why he would remove a fail safe, non-electrical, non mechanical (mostly) device and replace it with something which can fail if a connection gets loose or the electrical system acts up. The Insight is already a near death trap because of its tiny size and limited visibility; why reduce the vision even further? He claimed to get 80 plus mpg because of this mod and 13 coats of wax which no one walking by the car was allowed to touch.
    Frankly, I think the mods you propose would have little effect. The cone out the rear end would have to be longer than pratical to have any effect and you'd risk impaling a pedestrian who might happen to be standing behind you not hearing your electric motor.......
    Skirts? looks really hokey to me.
  9. tcrowson
    tcrowson New Member
    24
    I tested the car's MPG and then added the racing hubcaps and got .75 to 1.25 MPG with the new hubcaps. It seems that it reduces the airflow that goes "thru" the wheel thus improving the mileage slightly. Mike's hubcap wanted me to "drill" the rims to attach them but I drilled and tapped the "toyring", cut the bolds to .204" and screwed the caps to the toyring. I have about 400 miles on the car and they have not moved. Easy and cheep upgrade and it looks great.
    04 morph to 06 picture enclosed
  10. Godiva
    Godiva AmeriKan Citizen
    10,339
    13 coats of wax? What a waste of time, energy and product.
    There comes a point of diminishing returns. You can't layer was that much. It eventually emulsifies what's already on the car so you're only wiping it off again.
    Layering and diminishing returns
    "The law of diminishing returns as it relates to layering,
    A surface, such as an automotive paint, can only hold so much product before all you're doing is removing all subsequent coatings applied to the surface.
    That is to say, after the first, second and in some cases a third application/coating, any more product applied to the surface is merely removed when you wipe the excess off after waiting for the product to cure.
    At this point you've reached a plateau (or limit), as to how much wax (natural or synthetic) a surface can hold. Once you reach this plateau, all further applications of wax simply become excess that will be removed (and thus wasted), during wipe-off because it has nowhere to attach and layer.
    Of course, this all depends upon your definition of the word "Layer". If your definition of the word layer follows that of Webster's Dictionary:
    2 a: One thickness, course, or fold, laid or lying over or under another.
    Then yes, you can layer to a certain point. For example, you can add multiple layers of layerable waxes until the limit to how much a given surface of an automotive paint can hold before each additional application is simply removed, or replaces a previously applied layer."
  11. darelldd
    6,059
    389
    Northern CA
    Juuuust trying to make a point.
  12. Tori
    Tori Junior Member
    Thanks for looking into that. I am disappointed, but I'll just look at it as saving $85+, since I really don't think I want to go the screw-on route.
  13. TheForce
    3,461
    537
    Wheelersburg, Ohio
    I finally put my racing hub caps on today. I decided not to drill holes on the wheel and go with a more simple approch. I bought an extra set of trim ring from a member here and used the rings as a mount for the caps. This makes it much eaiser to remove them to check pressure and to change the tires. I used pop rivets to atach the caps to the ring. It makes a good connection but with only 3 points of atachment per wheel I feel I may need to add 3 more to each for a more secure connection. I dont think they will be flying off anytime soon but its better safe than sorry. I think it looks a lot better with these on. Makes it look more arrowdynamic and fast :) Now all she needs are some wheel skirts over the back. :) I took some pictures for you to enjoy and yes I need to wash and zaino my car. Its just a little too cold to do that right now. :(
    [attachmentid=2589] [attachmentid=2590]
  14. hyo silver
    hyo silver Awaaaaay
    15,266
    1,603
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    I'm going to draw the line at a bra - I mean mask. No panties or skirts for me. I could be talked into a riding crop - it would kinda go with the theme - if the uh...passenger were willing. :p
