SKS 2006 blinks the signal lights four (4) times when opening door - seems like an overkill?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by ZeroM8, Aug 22, 2021.
  1. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,803
    2017 Prius c
    Those are two different questions.
    12.19 after sitting for only 2 days is LOW.
    Could be the battery itself. Could be a parasitic draw more than normal.
    Could be that it wasn't charged up good the last time it was used.
    Now you need to do that over again after making sure that it is first fully charged and then removing the charger for 24 hours.
    The 13.89 reading indicates that the system is TRYING to charge it but a LONG time might be required.
    A fresh fully charged AGM battery should read between 12.8 and 13.0 with no load.
    In daily use, you would normally expect to see 12.6 to 12.8.
    Those tenths are important.
  2. ZeroM8
    ZeroM8 Junior Member
    74
    Toronto
    2001 Prius
    Hi Bisco and Sam Spade, thanks for the reply.
    I measured this morning:
    Car on and ready, engine not running,no accessories on: 13.89 V
    Car on , engine not running, accessories on: 12.16 V
    Accessory mode on (i.e. two presses on the power switch, not ready mode): 11.70 - 11.61 V, stereo at loud volume, headlights on, hazard on. Note headlights are in on, not auto as this turns it off at daylight.
    I plugged in my backup battery in parallel, leaving it with the car. Now it seems to work for now.
    After this I closed the car and operated the sks to open. Again 4 flashes (at one point it think it may have been five), went back in, close again, went back in, same number of flashes. Left the car for 2 hrs, expecting that should work. Nope, same SKS not working. I checked the backup battery and it's reading full. Unfortunately, I did not measure the voltage as I was in a rush.
    It does seem like it needs a certain amount of voltage to work, i.e. higher than, 12.6V? But just doesn't seems to be normal to be that picky.
    Do you guys know what runs this SKS system, e.g. ECU, or is there a separate module for it and WHERE might that exactly be. I am inclined to think maybe the supply to that has a big drop in voltage compared to the battery voltage, i.e. high wire resistance, faulty electronics that drops the voltage. If I can locate it, maybe I can find the issue, or I am tempted to just put a boost converter at it's input, they're cheap and widely available these days, I wouldn't imagine it drawing more than a few hundred milliamps on standby?
  3. sam spade 2
    7,035
    2,803
    2017 Prius c
    Well it seems that you did every possible test EXCEPT the one that you should have done.
    So, let's try again.
    Charge it up fully. Leave it sit overnight. Then measure the battery with EVERYTHING STILL OFF.
    Car not ON; engine not ON......dome light is OK.
    I think it is pretty obvious that you need a new 12 V battery.
    Whether or not that will solve what you perceive to be a problem with the SKS remains to be seen.
    51,977
    there is an ecu, under the center console maybe? o that may be one of the antenna's. the service manual would show the whole setup.
    are you saying everythingworks fine as long as the additional 12v source is hooked up?
  5. ZeroM8
    74
    Toronto
    2001 Prius
    Hey Sam
    Will try this again, but I have to set it up, as the car won't open the back hatch without first turning on the car, one of the quirks with this SKS acting up. So I have to open the door manually, turn on the car briefly to open the doors via the door button, turn off the car and measure the voltage. This is what I did last time to measure the voltage with the car off.
    The other choice I have is plug in my battery minder overnight via under the hood battery terminals, take it out in the morning, measure the battery to make sure it's over 12.6V, and see if the sks works.
    So you see my delimma here. I need patience and time to set it up.
    Here's what I haven't told you yet:
    The day after I got this car, the only key fob I had was left inside, with the metal key attached to it. It let me close it from the door button. I was pretty relaxed as my other Priuses would never let me close it when the fob is inside. Lo and behold, I realized when I went back inside the house, that I left the key in the cup holder. I had to call CAA the next day, as I didn't had a choice, good thing my brother still has his membership (cancelled mine years ago, testament to Prius reliability ).
    I also tried leaving all doors open, just to avoid the hassles of this SKS issue. I come back a few hours later or the next day, all doors are locked. Done it a couple of times
    Now I cannot say to people for certain anymore that you can never lock out a Prius
    And the troubleshooting continues on...
    #25 ZeroM8, Aug 31, 2021
  6. ZeroM8
    74
    Toronto
    2001 Prius
    Nope, still doesn't work even with the additional battery hooked up (additional battery showing full charge with its led indicator, though I did not measure the actual voltage...
    Any ideas where I can get a service manual, or if someone shared it here, would appreciate a link...tia
    That's what I've read somewhere here that there's something under the center console. What I need to know is where's the actual transceiver and / or any controller for the sks.
    Has anyone tried opening the center console area and how challenging that might be?
  7. ZeroM8
    74
    Toronto
    2001 Prius
    So I plugged in my trickle charger, at 1:30 am this morning, left the meter on the battery. It charged the battery. Went to the car, no response whatsoever with the fob blinking when I am close to the doors. So the usual dance of using the metal key, and the long beep when the car is turned on.
    The reading above is with the car off, I manually opened the car with the metal key, went around and opened the other doors manually (using MVIMG_20210831_105255.jpg MVIMG_20210831_105422.jpg the door locks, except the back hatch, can't open that)-and woke up the meter so see what the battery charge is. And there it is.
    Pretty sure it's not the battery from the beginning but we need a 100% confirmation.
    Now I have to looked elsewhere. I'm still waiting for the other new key fob I bought. But this is also 50/50 chance it's the key.
    I really think it's the car losing its memory of the fob or programmed fob. Is there a battery there somewhere that stores the information of the fobs inside the car, ECU, transceiver, etc?
    Someone sure knows this more than what little knowledge I have. Anyone?
  8. bisco
    51,977
    i have never heard of one. but i have read where people who are trying to program keys have the same problem. i can only think it is the fob or the programming.
  9. bisco
    51,977
    btw, i'm not sure about that voltage reading, it looks like a surface charge. disconnect the trickle charger, turn the headlights on for 5 minutes, shut them off, then check the voltage at the jump point
  10. sam spade 2
    7,035
    2,803
    2017 Prius c
    First, you need to get it straight in your head that you are NOT measuring the battery itself as long as you have ANY charging device connected and turned on.
    When a charger is connected, you are NOT measuring the battery itself but the voltage coming from the charger.
    When the car is "ready", you are not measuring the battery but the voltage coming from the onboard charging system.
    I have tried to tell you in a couple of different ways how to properly test the battery itself........but you just aren't getting it.......
    so I give up.
    Good luck.
  11. ZeroM8
    74
    Toronto
    2001 Prius
    Hey Sam, I think we're splitting hairs here. I am 99% the voltage is not the problem. Electronics used for the SKS should be able to ran at a range of voltage(s). I can understand if there's cut-off level which should be lower, but that would be totally insane if at a few tenths of a volt, say at voltage below 12.6V for example, and suddenly I cannot open my doors (unless the battery cannot deliver enough current / depleted - not the case here for sure). I've ran my 2004 at voltages well below the levels we are measuring, never had any issue once with SKS.
    Trying to drain the battery/getting rid of surface charge first (or removing the charger) and trying it out again I think would get us nowhere. And why with the charger connected would make a difference to how the SKS functions - if we suspect that voltage is low, the charger connected should aid in that issue. The power required to run the transceiver is likely a few hundred milliamps - maybe a few amps to unlock the door - but to initiate the response from the fob, and send that command to open the door should be just a few milliamps - but that initiation never happens. I am guessing it will probably ran on a 9Volt battery as well, if everything is in order. I have to move somewhere else to find the issue. I just wish the fob I ordered would come sooner, so I can see for sure if it's the programming, or the fob or whatever. This issue literally comes back a few seconds, maybe a couple of minutes, after the car is turned off after a long drive - which should charge the battery well. Why is that happening/i.e. losing it's memory of the fob is the root cause of all this.
    Thanks for your inputs. Will update when there's progress.
  12. ZeroM8
    74
    Toronto
    2001 Prius
    Hey Bisco, the charger is on almost overnight. If we suspect the voltage is low, having the charger there should aid in that issue, not impede it. I can see your point that running the headlights on for 5 mins to test if the battery is holding up it's end. But I think that's not the issue here. The issue is the car doesn't recognize the fob after as few seconds or a couple of minutes maybe of turning it off. I have to try out another fob, maybe that's the problem. I can't reprogram this only one I have in case it goes awry and I can't start the car anymore, or worse, have nothing to duplicate.
    Thanks, see also my response to Sam_Spade.
  13. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,091
    Columbia, SC
    Cycle the SKS button under the steering column a few times, see if anything changes.
  14. ZeroM8
    74
    Toronto
    2001 Prius
    Will try this and will get back when I have the results...
  15. ZeroM8
    74
    Toronto
    2001 Prius
    Hi I did this tonight, again without success. Thanks for the suggestion.
  16. dolj
    dolj Senior Member
    8,450
    4,291
    Wellington, New Zealand
    Not to belabor the point, but the 'Key' button is in the out position, right?
  17. bisco
    51,977
    maybe it is normal
  18. ZeroM8
    74
    Toronto
    2001 Prius
    Yes! Button is up, not pushed in. Easy to tell since there is a set button for the tpms, which is a momentary switch that's always on the 'up' position.
    Nevertheless, whether you use the sks system or not, the car would not open regardless of which system I use. If I leave it on non-sks switch position, it won't open the door with the fob, red led blinks when fob is pressed. And I can lock the doors with the fob inside. Same with SKS, it won't recognize the fob on entry.
    This happens about a minute of turning off the car. If you operate it within seconds of turning it off, it works fine, hence my 'losing memory' mentioned in previous posts. And off course, the title of this post, the blinks are in steroids. It blinks and unlocks the doors 4 times plus two more light blinks.
  19. ZeroM8
    74
    Toronto
    2001 Prius
  20. bisco
    51,977
    maybe someone changed the programming. there are some brilliant prius oewners
