SKS 2006 blinks the signal lights four (4) times when opening door - seems like an overkill?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by ZeroM8, Aug 22, 2021.
  1. ZeroM8
    ZeroM8 Junior Member
    74
    Toronto
    2001 Prius
    Ok, I finally figured out how to make it NOT beep during start. All other issues are still outstanding. Been very busy and didn't get the time to check the relay/fuse box by the driver footwell yet.
    1) unlock all doors using the driver side switch while the car still on
    2) turn off the car and lock all door switches manually, i.e. flipping the switches by hand
    Silly but it works. I can turn it on without having to embarrass myself next time I start the car :)
    I can live with this, if only I can make a duplicate of the START key !
  2. dolj
    dolj Senior Member
    8,450
    4,291
    Wellington, New Zealand
    That method does not set the immobilizer, so that would lead you to that area as a focus.
