SKS Fob stopped being recognized
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by russlan44, Apr 3, 2017.
  1. russlan44
    russlan44 Junior Member
    Rancho Cordova
    -sks fob stopped working
    -fob red light in corner works
    -buttons aren't stuck
    -started the car with fob in pocket and doors unlocked
    -ran inside the house to get my coffee mug car didn't beep (out of range) usually beeps
    -drove to work shut off car now car doesn't recognize fob unless in dash
    -wont lock or unlock from remote only metal key
    -messed with button under steering wheel (its pushed out)
    Im new to 04 prius and had mine for a month almost, so far so good. I have only one sks fob and red light on remote lights up when I press any of the 3 buttons, buttons don't stick, checked the button under neat steering wheel and its pushed out. Cant lock the car from any of the buttons outside nor unlock by touching handle or pressing buttons on remote. Unlocks only with metal key and can only start it with Fob being insert into dash, this all just happened this morning. worked fine before.
    I usually unlock the car by touching the handle, today I unlocked the car as usual, started the car with key fob in my pocket, forgot my coffee mug in house, ran out the car to get it, didn't hear the usual beep from car that key isn't in range, drove to work, on way out the car door shocked me, tried locking the car with pressing driver side button, didn't work, tried remote didn't work, jumper back into car it wouldn't start unless I put fob into dash, shut off the car pulled the fob out from dash tried starting the car with fob out yellow dash key came on as it wasn't present, tried messing with button under neat steering wheel, it was pushed out and I clicked it couple times, still would only start with fob inside dash. Got out the car, closing door it shocked me again and tried locking from black square button on door handle or remote doesn't work, only locks and unlocks with metal key. Please help
  2. JC91006
    16,827
    8,600
    I think you should change fob battery
    Kevin_Denver likes this.
  3. DonDNH
    DonDNH Senior Member
    1,711
    655
    Nashua, NH
    Four Touring
    ... and check the condition of the 12V as well. Either or both could be the cause of your problem.
  4. russlan44
    Rancho Cordova
    thanks guys for quick response, just came back from a walk with co-workers and venting to them as I was coming close to the building I pulled clicked the remote unlock button from about 25-30 feet and car unlocked, hit the lock button and it locked, I came close to it, grabbed front pass door handle and it unlocked and I opened the door and closed the car with hitting outside black square on door handle.
  5. russlan44
    Rancho Cordova
    I will be looking into changing the key fob battery just to know its new when my key fob shell arrives from ebay sense mine is beat up and worn out, does the fob has to be reprogramed after battery install?
  6. Kevin_Denver
    Kevin_Denver Active Member
    581
    425
    Denver, CO
    Mine did the same (worked only intermittently) when my fob battery was dying. Replacing it fixed it.
  7. valde3
    valde3 Senior Member
    2,002
    750
    Finland
    You don’t need to reprogram anything when changing the key battery.
    When swapping the key internals to a new shell remember to swap the chip too! Other vice key doesn’t work in the slot and can’t be used to program new key.
  8. dolj
    dolj Senior Member
    8,549
    4,341
    Wellington, New Zealand
    No, but as valde3 advised make sure you move the RFID chip over to the new shell, it looks like a small rectangular piece of plastic (on the inside of one half of the old shell), and may have markings on it common to communications equipment.
  9. russlan44
    Rancho Cordova
    So after 3 days of messing with small key today i got a new battery for the remote, doors unlocked right away and locked from remote, but leaving work SKS didnt work again, the little red light flashes on remote but won't unlock or lock nor SKS work, had to do use the small metal key and put the fob into ignition for it to start and drive.
  10. bisco
    52,351
    how is the 12v health? did you move the chip into the new case?
  11. Tideland Prius
    16,610
    I wonder if it's the external receiver. Are you able to use SKS to unlock the hatch or the front passenger door?
  12. russlan44
    Rancho Cordova
    12v battery was low that it wouldn't start the car, this was a month ago, took it out and charged it up and car started up right away been driving for a month with no issues with car battery. And haven't received my new shell, didn't look where i ordered from while checking out on ebay and its coming from china.
    Doors or hatch doesn't externally tried the handles and hatch no go
  13. bisco
    52,351
    test the 12v after the cars been off for a few hours. just because it starts, doesn't mean it's good. my 2004 12v was slowly dying, the fob was doing funny things, but the car would start fine.
  14. russlan44
    Rancho Cordova
    will check the battery tonight, if low voltage will throw it on charger overnight.
  15. russlan44
    Rancho Cordova
    battery is at 14.5v, car been standing without use for 4 hours
  16. dolj
    dolj Senior Member
    8,549
    4,341
    How are you measuring the voltage?
    If you are using a multi or volt meter, when was the last time it was calibrated. Or are you just using a cheap one?
    If you are using the MFD, then the car needs to be in ACC mode, not READY.
    14.5 V is a whacky reading if the car is really OFF, so something is amiss, if that's the case.
    valde3 likes this.
  17. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    14.5v? The DC to DC inverter must be online, a standby voltage of the 12v battery should be 12.Xv or lower.
  18. russlan44
    Rancho Cordova
    14.5v was using cheap electric harbor freight volt meter.
    Got a used sks key fob from ebay, registered it, car starts with it, tried registering sks mode, when got to the point when you hold the lock and unlock on old remote for some times and doors would lock and unlock, nothing happened then i grabbed new remote and held lock and unlock at same time, doors locked and unlocked, pressed the lock on new remote and it worked to exit registration mode i just openned the door. Tried the new remote sks mode, doesnt work, tried hitting lock and unlock doors didnt do anything. Will try to re-register the remote again. Would unhooking the battery from car for sometime reset anything?
  19. dolj
    dolj Senior Member
    8,549
    4,341
    I don't believe you can get the SKS working using a used remote. You have to use a brand new SKS (silver logo) in order to program it with the chicken dance.
  20. russlan44
    Rancho Cordova
    I did the chicken dance with used SKS remote, while adding sks option from priuschat write up, it will unlock and lock the doors but when i open the door or insert the fob to exit out from registering remote doesn't unlock nor lock doors anymore.
    -both remotes still dont unlock nor lock the vehicle only start (my original and one i got off ebay)
    -checked the voltage on battery unhooked from the car it was at 13.0v with HF volt meter.
