SKS Keyless Entry does not work Prius 2005
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by doctorman, Aug 5, 2020.
  1. doctorman
    doctorman Member
    210
    36
    NY 11020
    Have 2 FOBs that stopped working wirelessly , they work when I plug them in to turn the car on,
    The red LED on FOBs turn on when buttons pressed
    12v battery is checked and is good
    KEY SKS button under steering wheel checked multiple time, it is not that
    FOBS do not work even when placed directly on top of the power button, by driver side, passenger side and hatch.
    The only function that works on FOB now is driving the car by entering the FOB in the slot.
    both FOBS act the same so it is not the FOB.
    The only thing that recently happened is the windows left open when there was a bit of rain so the passenger and driver seat got a bit wet.
    No engine light issue.
    I have techstream to help with diagnostics but have not used it yet ..
    Would appreciate any help on this
    #1 doctorman, Aug 5, 2020
    52,863
    check the 12v health
  3. doctorman
    doctorman Member
    210
    36
    NY 11020
    checked, that is not the issue
    52,863
    maybe some moisture got into one of the antennae ecu's
  5. doctorman
    doctorman Member
    210
    36
    NY 11020
    the question is how do I proceed to diagnose and repair
  6. bisco
    52,863
    you can try hooking up tech stream, but idk if it will pick up any codes if therearen't any trouble lights. it's worth a shot
  7. dolj
    dolj Senior Member
    8,652
    4,401
    Wellington, New Zealand
    When you say, "it's not that," do you mean the button is in the SKS enabled position which is the "out" position? The "in" position is SKS disabled. Just asking to be clear what your situation is, as your description of the problem sounds like the SKS is disabled.
  8. doctorman
    doctorman Member
    210
    36
    NY 11020
    tried both in and out
    whn it is out , meaning SKS enabled, pressing the start button without the key plugged in, turns on the yellow security light on dashboard meaning key not recognized
    so yeah the antenna is not picking up the key
    is it it one antenna?, is it just an easy swap or do I need programming
  9. doctorman
    doctorman Member
    210
    36
    NY 11020
    looking at the picture in post 1
    there is room oscillator and the door receiver on the passenger side
    considering it is an antenna issue and everything else works my money is on these two
    Any idea how to differentiate between which is the issue
  10. bisco
    52,863
    probably not without tech stream. there is one in the center console, iirc
  11. doctorman
    doctorman Member
    210
    36
    NY 11020
    Techstream read code B2775 under immobilizer
    resetting it did not make it come back immediately
    system still the same
    tried reading ACTIVE Data and tech stream crashes no matter what I do
    v13
  12. bisco
    52,863
    techinfo.toyota.com
  13. doctorman
    doctorman Member
    210
    36
    NY 11020
    seams like the transponder ECU
    also known as the Immobilizer ECU located on the right side of the steering wheel in the dash
    Toyota part number 89780-47030
    might be the issue, or could be a connection issue.
    if that does not solve it, then it is the certification ECU which I still do not know the part number for it.
  14. bisco
    52,863
    electrical issues are often the toughest to diagnose
  15. WilDavis
    WilDavis Senior Member
    2,493
    2,155
    49
    I bought my 2009 Gen II in 2014 and both occasions when I've had a problem with the SKS, it has turned out to be the batteries in the fob. hope this helps - Good luck! - Wil
  16. doctorman
    doctorman Member
    210
    36
    NY 11020
    @Elektroingenieur would appreciate your insight on this please
  17. doctorman
    doctorman Member
    210
    36
    NY 11020
    10 days later in the heat of summer the car went back to normal
    My guess is some water got into the part of the SKS systems and evaporated
    hopefully it will stay that way
  18. thejaycan
    thejaycan Junior Member
    Seattle, WA
    Question for you @doctorman, I seem to have the same symptoms you do. When your fobs weren't working with the keyless entry/start, did the unlock/lock/panic buttons on the fob work or did that not work either? (Those don't work for me).
    I've been fighting this issue for a bit, the warmer temperature did get it working again for me for a while (a month or so) but now the problem is back.
    I did a really interesting test but the results are confusing. I started the car with the key in the slot, but not all the way in where it locked, just enough to start it and pulled the key out. With the car in ready mode I took the key outside the car and closed the door. The car beeped three times. I then opened the door, put the fob on the driver's seat and closed the door. No beeps. So the car is detecting the fob, but why doesn't it work to start or smart entry or even lock/unlock with the buttons on the fob? Head scratching over here.
  19. doctorman
    doctorman Member
    210
    36
    NY 11020
    I bet there is a rusty dirty connection in the ECU or its connection, if its happening again maybe just change it and get it over with , it is a cheap part on ebay , but again it could be anything else
    my button on the fOB did not do anything when it was not working
  20. thejaycan
    Seattle, WA
    I fixed it today, my Door Control Receiver (p/n 89741) went bad. I fired up Techstream and was getting Code Mismatch and time out errors from the key so I suspected either the harness, the Door Control Receiver, or the Certification/SmartKey ECU. I didn't have any good reason to suspect the harness and the Door Control Receiver is way easier to get to versus the Certification ECU (taking the whole dash apart) so I started there. Bought a used one from ahparts and put it in and problem solved.
    Hope these threads help other people with SKS problems.
    SFO and doctorman like this.
