SKS Keyless Entry does not work Prius 2005
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by doctorman, Aug 5, 2020.
  1. doctorman
    doctorman Member
    210
    36
    NY 11020
    thank you so much! it makes sense that was the part I needed as well since my window on the passenger side was open and rain gt in ...
  2. thejaycan
    thejaycan Junior Member
    Seattle, WA
    Well, the Door Control Receiver is in the trunk area. It's basically right above the gas tank fill port on the driver's side. I ended up removing the bottom interior cover panels but it's in the top panel area so don't do what I did. I wish I took a picture or two...
  3. dolj
    dolj Senior Member
    8,627
    4,381
    Wellington, New Zealand
    As well as Door Control Receiver, but there are five oscillators (as they are called), one in each of the front doors, one behind the center console, one in the trunk (behind the HV battery), and one in behind the rear bumper cover. I was wondering as the part number you gave was for the Receiver, Door Control. The two front door ones have a different part number, 89991-47010 – Oscillator, Door Electrical Key. The other three oscillators have a different part number again.
    I would think doctorman would need a front door oscillator as his problem started when some rain got inside the car from an open window.
    #23 dolj, Sep 4, 2020
    SFO, Dammy and doctorman like this.
  4. thejaycan
    Seattle, WA
    Right, I agree with you. Mine ended up being the door control receiver so it's likely a separate issue from what doctorman is experiencing. I was just following his thread as he said his problem just went away with warmer weather. Mine initially did first (around 2 months) before finally failing.
  5. AAslam
    AAslam New Member
    Norway
    I am also experiancing the same problem. I got the battery checked from Toyota and everything was ok. Tried to get a new key programed manually the workshop configured The key AS a starter key but could not configure keyless. The workshop Said the car is not recieving any signals but is sending signals.
    What do u guys suggest.
  6. dolj
    dolj Senior Member
    8,627
    4,381
    Which battery?
    The key was probably not new, but second-hand. You cannot fully program a second-hand key, without doing a full reset and reseed if your car is non-SKS, and if it is SKS, only a new key will do.
  7. Dammy
    Dammy Junior Member
    Nigeria
    My sks not working but the fob button is working.
    I also discover that the central lock is not working when engage my gear in drive. Any help to solve this problem
  8. Sue Airabex
    Sue Airabex Junior Member
    I replaced my door control receiver but do not know how to program the key jfobs so they can communicate with it. Can anyone help? thanks
  9. Name:
    23
    Salinas, CA
    Me too! My door control receiver had water damage, so I replaced it, but SKS functions are still not working. The fob blinks as soon as I unpush the button under the steering wheel. I know this is an older post, but I was wondering if you ever solved it?
