SKs not working after 12v battery change
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by f18cmech, Dec 25, 2018.
  1. f18cmech
    f18cmech Junior Member
    52
    San Diego
    hello all, just wanted some help on an issue with the sks system now working anymore after installing a new 12v battery and both key fob batteries. I know the 12v is charged and healthy because i tested it and it reads 13+ volts and has 345 cca. Can anyone chime in on what else might be the cause? Thanks.
  2. brdmb
    brdmb Junior Member
    17
    Ohio
    Nortnarg likes this.
  3. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,481
    Bay Area, California
    2019 Prius Prime
    What is the voltage on the key fob batteries?
    Does the light on them light up and no buttons are sticking?
  4. f18cmech
    52
    San Diego
    Have tried all of these. Batteries are new
  5. f18cmech
    52
    San Diego
    However the battery is a refurb not new. It is good though.
  6. Raytheeagle
    11,251
    15,481
    2019 Prius Prime
    So the voltages read?
    edthefox5 likes this.
  7. f18cmech
    52
    San Diego
    My volt meter is at work. You mean they may package bad batteries?
    Raytheeagle likes this.
  8. edthefox5
    edthefox5 Senior Member
    10,096
    4,804
    Clearwater, Florida
    Refurb battery? How do they do that?
  9. edthefox5
    10,096
    4,804
    Clearwater, Florida
    Does the fob light it’s little led red light when you push the button?
    Does emergency alarm button work on both fobs?
    Does the car start if you insert the fob in the fob slot under the steering wheel?
  10. Raytheeagle
    11,251
    15,481
    2019 Prius Prime
    Anything is possible ;).
    Only way to know is to test and verify the voltage is around 3.3 volts:).
    Happy holidays (y).
    f18cmech likes this.
  11. f18cmech
    52
    San Diego
    Good question. It’s what they call them although “used” is the more correct term.
  12. f18cmech
    52
    San Diego
    Yes to all the above. Just can’t get this alarm to work for the life of me.
  13. padroo
    padroo Senior Member
    2,763
    2,250
    You could buy a key fob tester.
    #13 padroo, Dec 26, 2018
  14. bisco
    49,371
    where do you buy a refurb 12v?
  15. f18cmech
    52
    San Diego
  16. f18cmech
    52
    San Diego
    Google it
  17. padroo
    2,763
    2,250
    There used to be a warehouse not too far from where I live that sold rebuilt batteries. It was a warehouse type place and I did buy one but don't remember how it worked out for me.
  18. bisco
    49,371
    is it a prius battery?
  19. f18cmech
    52
    San Diego
    I was fortunate to get a good used one. Not sure what they do to refurb it, but it appears they charge it and test it and make sure it has electrolyte
  20. f18cmech
    52
    San Diego
    It’s a fvp, most likely rebranded but it has the exact rating the Toyota true start even the part number is the same it’s gray with a yellow top and fits perfect in the slot.
    padroo and bisco like this.
