SKs not working after 12v battery change
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by f18cmech, Dec 25, 2018.
  1. f18cmech
    f18cmech Junior Member
    52
    San Diego
    As a final effort, I’m leaving my Prius on all day while I’m at work and see if that brings it a full charge. Last time I did that it worked albeit the battery was old and failing. We shall see!
  2. JC91006
    16,936
    8,647
    You'll just be wasting gas. If the car starts, it's not the bad causing problems to SKS
  3. f18cmech
    52
    San Diego
    My last ditch effort is to leave Prius in ready for 9 hours while I’m at work and hope this at last brings this battery to a complete charge. It worked on my last battery, hopefully I will have keyless entry at last
  4. f18cmech
    52
    San Diego
    To the contrary, the car has always started but not until I charged it this way did I get keyless operation.
  5. JC91006
    16,936
    8,647
    If the battery has enough juice to start the car, it'll have enough juice to work the SKS.
  6. f18cmech
    52
    San Diego
    Yes you would think so. But all I know is it work after a long drive or letting sit in ready for a while. Not sure what else could be the issue really
  7. JC91006
    16,936
    8,647
    You've changed the battery in the keyfob correct?
  8. f18cmech
    52
    San Diego
    Si. Beginning to think it needs a new fob at this point?
  9. JC91006
    16,936
    8,647
    1. Does the lock and unlock buttons work?
    2. Do you have a spare Keyfob?
    If the lock and unlock buttons work, I would try to do the SKS programming steps (aka chicken dance) again and see if the functions return.
  10. f18cmech
    52
    San Diego
    No spare fob, and no no door locking unlocking or keyless start. The only thing the fob does right is allow the car to start with it in the slot. And the red light lights up. Other than that, nada
  11. JC91006
    16,936
    8,647
    Do you have any stuck buttons on the fob? lock/unlock/panic. When you press them, do you feel them clicking?
    Did your fob work correctly at one point? All the buttons worked and sks worked?
  12. f18cmech
    52
    San Diego
    Yes, they worked on and off, with sks, but only after a complete charge of the batteries. Now, I have changed the 12 volt with a good battery, and they only worked briefly now never at all even after a 8 hour charge. The battery voltage shows 12.8 when you check with the screen, power button pushed(not in ready). I’ll change the battery On the fob and see what happens.
  13. f18cmech
    52
    San Diego
    Another thing i noticed Is sometimes after pressing a button the little light blinks 3 or four times in a row I thought it was pairing with the car but it doesn’t work to unlock just the light will blink by itself a few times
  14. f18cmech
    52
    San Diego
    Ok, here is the latest. Now, the sks system works(don’t have to push any bottoms) car starts without the fob in the slot but the buttons don’t unlock the car. Just the sks. Thoughts?
  15. JC91006
    16,936
    8,647
    You should replace the key fob battery again once it stops working again.
  16. f18cmech
    52
    San Diego
    Well, new fob, battery charged, no sks. I’m at a loss.
  17. JC91006
    16,936
    8,647
    It must be the fob with the issue. Since you don't have a working spare, getting a new one from the dealer will be $300+
