SKS Trouble on 2006 Prius
Discussion in 'Gen 2 Prius Main Forum' started by okiedokie, Jul 10, 2016.
Tags:
  1. okiedokie
    okiedokie Junior Member
    WV
    Hi Everyone,
    I have a problem with one of my Smart Keys. Car was purchased used with 2 smart keys one of which had a lot more wear than the other. One is working just as it should. The worn one stopped working except when it is inserted in the dashboard key slot. I replaced the battery and now the red LED flashes with all 3 buttons; however they do not Lock, Unlock, or Panic anymore! Car does not respond at all! I have read that the keycode is unique to the key fob and that code ought to be already accepted by the car. What do I have to do to get this key working again? I am getting a new aftermarket shell and plan to make the key look better and replace the missing red button.
  2. JC91006
    16,827
    8,600
    That key probably doesn't belong with the car, verify all 3 buttons are not stuck and click when pressed.
    Best to just buy a brand NEW key online for around $100 to replace it. You can program it yourself with instructions posted in this site. You don't have to waste money on a new cover either
    #2 JC91006, Jul 10, 2016
  3. okiedokie
    WV
    Hi JC,
    It did work and I had been using it for a week or two because my other FOB seemed to be weakening. Took my car to a repair shop about another issue and the service manager and I could not get the remote functions to work. So I pushed it into the dash key slot and voila! it worked. When he finished I used the remote functions successfully for about a day and a half before the ship really hit the sand. The LED stopped working altogether except occasionally the LED lit when I hit the Panic button. Got a new battery and installed that and now the LED lights with all buttons, but car just does not respond.
  4. JC91006
    16,827
    8,600
    You can try swapping the 2 batteries and trying it again, you know for sure 1 battery is working properly.
    Still make sure you have no stuck buttons
