Slammed the front into a Semi.
Discussion in 'Gen 3 Prius Main Forum' started by Saucey, Oct 26, 2022.
  1. Saucey
    Saucey Junior Member
    San Diego
    As the title implies.
    Had to get a tow because I wasn't sure what happened.
    Airbag deployed for the driver, steering wheel and knee, nothing else.
    Only have liability, collision center said to take it home.
    Couldnt move the thing, was able to push into neutral.
    The car's horn is beeping quietly but at a fast pace.
    Once towed at home, I disconnected the battery for about 1 minute. Was able to reverse it. Front bumper is jacked, hood and luckily turn signals and lights intact.
    Thinking of trading it it lol but idk what I'll get with the airbags deployed for the driver.
    Thing is.... I may drive it jacked with Bungie cords, and replace the $300 hood.
    Problem is that after I removed the battery I was able to drive the machine with some warnings. But it still does the quick light beeps for the horn. .
    52,736
    sorry to see it!
    don't you get a salvage title if the airbags go off?
    if everything works, i would clean it up and keep driving
  3. Tombukt2
    Tombukt2 Senior Member
    13,778
    2,495
    Durham NC
    Hood can be had for 180 online special from lot of Toyota dealers themselves like in my area which is Rick Hendrick
  4. ttou68
    ttou68 Active Member
    351
    211
    Don't look too bad from the picture, but won't know until seeing under the hood..
    Air bags can be replaced, and the horn may have a short cause by collision. Check wiring to horn... Good luck!
  5. fuzzy1
    10,687
    Airbag deployment suggests more damage than just the hood damage we can see in the picture.
  6. douglasjre
    douglasjre Senior Member
    2,242
    749
    Null, NL
    If you're still on the original engine battery pack brake booster accumulator ABS controller radio shocks and struts then it probably won't be worth fixing because you still have an uphill battle on all that stuff after you do the body work. You might do better parting it out
  7. Saucey
    San Diego
    Yeah I gotta get the hood open, had just went to bed after this post (night job). Time to pick up a bike
  8. Leadfoot J. McCoalroller
    8,255
    7,759
    Pennsylvania
    2018 Prius c
    Technically airbag deployment means there was a very sudden (negative) acceleration. But it is possible that the energy was dissipated evenly enough across enough cheap body metal that you won't wind up replacing that many technical parts other than the airbags.
    From the length of scratches on the hood, it's obvious that some of the impact energy was used to lift up the back of the semi and compress the front springs on your car. That's in your favor in terms of repairability.
    Good luck and glad you're ok!
    CR94 likes this.
  9. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Since no one is willing to ask, what caused you to slam into the semi truck?
    crooner and Mendel Leisk like this.
