Sleeping in hybrids- a/c run all night off battery?
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Haraald, Mar 26, 2017.
  1. ice9
    ice9 Active Member
    581
    344
    norfolk va
    2018 Prius
    Because... ...we CAN!!! :)
  2. Prodigyplace
    12,570
    11,782
    Central Virginia
    Because they already own it & the climate is mild enough to permit it?
    Tim Jones, Data Daedalus and krmcg like this.
  3. ice9
    ice9 Active Member
    581
    344
    norfolk va
    2018 Prius
    I could have sworn I heard crickets! :whistle:
  4. Data Daedalus
    Data Daedalus Senior Member
    1,025
    1,185
    Wembley, London
    There’s more space in a Prius 2nd Gen than there is in a Mercury or Gemini Space Capsule I’d wager.
    Of course one person can camp out in a Prius II easily with the right equipment, and thoroughly enjoy the experience .
    iPhone 6s +
    1prius and krmcg like this.
  5. noonm
    noonm Senior Member
    575
    595
    2018 Prius Prime
    Loads of people do it. A quick selection from youtube:
    1x1, douglasjre and Prodigyplace like this.
  6. douglasjre
    douglasjre Senior Member
    2,181
    720
    Null, NL
    Why would anybody want to ski dive
  7. ChapmanF
    18,249
    Easier than ski climbing.
    Fubar XIII and krmcg like this.
  8. avongil
    avongil Member
    67
    56
    Easton, PA
    I have also seen people put another 12v battery in parallel in order to get more time before recharge cycles when they are using alot of 12v power - usually a 120v inverter.
    if you can handle less space the prius prime goes all night without starting up at all. It also has a recharge mode so you can recharge the 9kw battery without plugin in if you need to do super stealth camping.
    Data Daedalus likes this.
  9. KRISTJAN ANTALIC
    KRISTJAN ANTALIC Junior Member
    16
    SAN ANTONIO, TX
    2018 Prius Prime
    The Prius Prime will not let you sit in the car and run the a/c for more than 10 minutes WHILE CONNECTED TO A CHARGE POINT. I consider this a design flaw and a security risk. If the weather is hot or cold, or if the neighborhood surrounding the charge point insecure, the safest place you can be is ensconced in your car listening to the radio and running the climate control, with the doors locked. Does anyone know why Toyota forbids this?
  10. bisco
    51,996
    maybe there is a problem with charging the battery, and draining it at the same time?
  11. Johnny Cakes
    Johnny Cakes Senior Member
    1,049
    780
    Virginia, USA
    I'm against people reviving very old and dormant threads, but just have to correct this.
    Another battery in parallel will NOT increase the time before recharging cycles.
    In READY mode, 12v power is provided by the high voltage traction battery using a DC to DC converter, not the 12v battery. A second battery is just another load that the traction battery has to provide electricity for, so it would actually decrease the time between recharging cycles.
    The 12v battery is mostly used for firing up the computer so that the traction battery can start the car and establish READY. A second 12v battery in parallel will also permit longer ACC (accessory mode) time. Only in ACC mode are you actually using the 12v battery to supply power.
    Once you are in READY mode, the 12v battery is just a draw on the traction battery. All power in READY mode is obtained from the traction battery.
  12. Danny13pruisc3
    175
    27
    maryland
    If you're using a DC to AC converter on the 12v then I think J Cakes scenario makes sense and doesn't need correcting..
  13. Tim Jones
    Tim Jones Senior Member
    1,758
    565
    SE Texas
    2011 Nissan LEAF
    The engine will come on at least 10 to 15 times a hour with the ac on.......get a window air conditioner.....
  14. Fubar XIII
    Fubar XIII Member
    63
    38
    Metro Detroit
    Maybe I'm old-fashioned but I thought the whole purpose of camping was to get outdoors, be in nature, etc. :confused:
    And one of the reasons to own a hybrid is to save the planet, use less fuel, put less CO2 into the atmosphere, etc., so we CAN still go outside and not burst into flames.
    So why, WHY, would anyone ever want to go to the great outdoors then hide inside a car?!?!? Put another way: Why go to Italy for the cuisine then only eat Mickey D's? :eek:
    Buy a tent, a good-sized one you can stand up in, put it up in the shade. Get some lightweight clothes, breathable fabrics. Maybe a beer or a swim in the ol' swimming hole if you get a touch warm. Or learn to deal with the temp., 'hot' & 'cold' are mostly mental anyway.
    That said, to the question. Here in FL, A/C set at 75F, fan on setting 4, DRLs off, radio on, in a shady spot with a full charge, outside temp in the low 90s (std FL 6-month long summer daytime temps) my battery is drained enough to kick the ICE on (2 bars) in about 15-20 mins. ICE runs long enough, about 3 minutes, to put it back to 3 bars. Then it's every 5-ish mins until I drive it. I won't get into how the MPG plummets.
    Tim Jones likes this.
  15. Tim Jones
    1,758
    565
    SE Texas
    2011 Nissan LEAF
    I find that hard to believe
  16. Tim Jones
    1,758
    565
    SE Texas
    2011 Nissan LEAF
    What a grouch............................!
    krmcg likes this.
  17. douglasjre
    2,181
    720
    Null, NL
    I can't sleep if T over 70F or humidity over 50%. I tried. No sleep. Not kidding. None. At 6am I'll still b awake. Not kidding.
  18. Fubar XIII
    Fubar XIII Member
    63
    38
    Metro Detroit
    You live in the sweatbox of Orlando!!! It's hotter & more humid there than by the coast. How many years have you been without sleep?
    You need to live in Nunavut, or northern Alaska, maybe Siberia with those needs. Even Iceland is too warm for you. Good luck.
  19. douglasjre
    2,181
    720
    Null, NL
    Fubar: My first floor home ac is a 5 ton heat pump that gets humidity down to 35% and 70f for second floor is a 2 ton also set to slow fan speed. Nice and dry. How about yours? Does yur AC work well?
  20. Fubar XIII
    Fubar XIII Member
    63
    38
    Metro Detroit
    Yeppers. Keeps me a comfortable 78 F. Until "fall" shows up in Nov and the high temps finally drop under ~82 & the lows start getting into the mid-60s then the windows get opened until mid-April(-ish) when summer reasserts itself.
    All that gets me $65 summer bills & sub-$30 winter bills. This place is seriously well insulated & I've got great shade from some mature live oaks for a natural assist.
