Slightly larger spare tire..
Discussion in 'Gen 3 Prius Accessories and Modifications' started by WesleyRiccipio, Aug 22, 2022.
  1. WesleyRiccipio
    WesleyRiccipio Junior Member
    103
    24
    Hi all,
    I am getting my prius lifted and want to have a new spare tire since it's over 10 years old anyways. I don't know much about tires and was hoping someone could help me.
    Would the below specs fit a 2010 with existing 17" wheels for however many miles a spare ties needs to go?
    17" Spare Tire Vredestein Bridgestone
    Porsche Cayenne
    Fits Porsche Cayenne, VW Toureg and Audi Q7
    Rim Material: Steel
    Rim Width: 6 1/2 JX
    Offset: 53
    Number of Bolts: 5
    Rim Brand: Porsche
    DOT: 1303
    NEVER USED!
    PN# 4L0601027
    100% OEM
    Thank you!!
  2. Mendel Leisk
    42,296
    Current spare is probably still fine. How does it look?
  3. WesleyRiccipio
    103
    24
    Here it us
    52,803
    keep in mind that it comes with a donut. idk if a regular wheel/tire will fit in the well
  5. WesleyRiccipio
    103
    24
    Right, yeah, please see above ;)
    Whatever takes up less space in the car, I would want to go with. I am thinking that the inflated 15" spare is going to take up as much space as the deflated 17". that would be funny if I bought it and it was the same haha.
  6. Mendel Leisk
    42,296
    Yeah fugedaboutit.
  7. WesleyRiccipio
    103
    24
    forget about replacing it, or forget about using the spare tire that I showed a pic of?
  8. Mendel Leisk
    42,296
    About replacing it. Still, if you’re going to go through with this:
    Do you have the replacement on hand? If so why not just try it, both for fit under the hatch floor and installed. If it’s grossly different outside diameter the car’ll probably throw codes, if you test drive.
    also, the description of the new tire does not include size spec. As an example: 195/65R15.
  9. WesleyRiccipio
    103
    24
    whoops. Here it is: 1 X VREDESTEIN UNUSED AUDI SPACE MASTER SPACE-SAVER SPARE TYRE 205/70-16 97P
    I dont have it. would get it on ebay
  10. Mendel Leisk
    42,296
    Buying a non-Toyota temp spare seems a big gamble. And, it just might be older rubber than what you’ve got now.
  11. WesleyRiccipio
    103
    24
    True.. I will probably just keep it. Trying to make the most out of the space
  12. jzchen
    jzchen Newbie!
    3,316
    1,022
    Arcadia, CA
    That tire is HUGE.
    Don’t really like flat spares as a side note.
    I’m afraid you won’t even be able to get it on the hub. Bolt pattern might be different seems like TireRack pulled that spec so don’t know where to check… IMG_0014.png
    iPad ?
    #12 jzchen, Aug 23, 2022
    WesleyRiccipio likes this.
  13. black_jmyntrn
    black_jmyntrn Senior Member
    1,729
    410
    2013 Prius Plug-in
    I feel like a subaru wheel would be a better option but you should try to find a wheel that is exact to the wheels you have now and tire to match. Any variation of your spare from the wheels and tires you have on the car isn't recommended.
    Have you tried finding the part number to your wheels and then searching auto dismantlers to see if they have it? Those places would have 1 or 2 and sell for a lower price. Or craigslist... When I had a flat in my plugin while at the grand canyon, I found a full size 15" spare and with new tire for $50 in Vegas, I borrowed a fellow Prius owner's spare tire, and we drove to vegas before heading home to LA
  14. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Don’t let others tell you no. Porsche tire is top level quality.
  15. WesleyRiccipio
    103
    24
    wow! quite a story. prius owners stick together. or at least at the grand canyon.
    my tires are in the mail. they arrive tomorrow so ill look then
  16. black_jmyntrn
    1,729
    410
    2013 Prius Plug-in
    all 5 right? your best bet is to find a wheel that matches yours. that way when you rotate tires, you rotate in the 5th wheel. That's what I do and I just redo the tpms so it knows which wheel is now on the car.
