Slip indicator comes on when at a full stop
Discussion in 'Gen 3 Prius Main Forum' started by ratpack, Aug 10, 2009.
  1. quantumslip
    quantumslip Member
    149
    Sugar Land, TX
    yep i know that. just a habit picked up from driving cars without that feature
  2. Tad Moody
    Tad Moody New Member
    35
    Duarte, CA, USA
    I live on a very steep hill. When I get home, I stop at the mailbox at the end of a long, steep driveway, and the hill assist is terrific to keep me from rolling backwards when I take my foot off the brake.
    Before the Prius, I've had years of practice perfecting an uphill start with a MANUAL transmission: takes a little fancy footwork, a "toe-heel" kind of thing with the right foot holding the brake and accelerator at the same time, while the left foot lets out the clutch. NO Thanks! This is MUCH nicer, especially now that I'm older, and.....lazy-er. ( is that a word?)
  3. Tideland Prius
    16,670
    yeah it's word. It's spelled lazier =)
  4. Casi
    Casi Junior Member
    17
    New Jersey USA
    2023 Prius
    XLE AWD-e
    Thanks all... I never knew that the feature was a "Hill Assist".
  5. pedro162
    pedro162 New Member
    New York
    I have my car ABS Actuator fixed today, now the car stop too fast and the brake actions does not match the Energy Monitor activity plus the pedal it is harder to push.
    When the brake it is apply and the car stop fully it shows that the Electric Battery is supplying power to the electric motor, only when you push the pedal harder to the floor the supply of energy stop also after stopping and the car is let roll down hill by gravity there is no show of energy flowing either way.
    I even saw the slip light come on while breaking ( hard) to stop the battery from sending energy to the eletric motor according to the Energy Monitor indicator
    This brake solution need more work done
  6. hsiaolc
    hsiaolc New Member
    617
    46
    UK
    It will turn off without you pressing it again.
  7. Tideland Prius
    16,670
    If you brake lightly and come to a stop, there is still energy flowing from the battery to the motor to the wheel. This is the automatic creep function that's built into the hybrid system to simulate a normal automatic vehicle. You are right in that you do have to press harder to stop this feature. It's normal.
    No energy flow is normal HOWEVER, it should quickly switch to regenerative braking (arrow from wheel to motor to battery) when you're going downhill. The moment where there are no arrows should be very short-lived.
    If you press the brake pedal all the way to the bottom past a little denté, that's the Hill-Start Assist that you activated. It will beep once and blink the Slip Indicator. When you lift your foot off the brake pedal, the car will hold the brakes for 0.8 seconds to give you time to move your foot over to the accelerator.
  8. JasonPro
    JasonPro Junior Member
    72
    Rockville MD
    I have to say that I'm a bit worried that all these people who don't read their manuals and then complain that their traction control is going crazy to Toyota are going to convince Toyota to remove the feature entirely. I like Hill Start Assist just the way it is. I use it on several steep hills around my neighborhood. It lets me not feel like I need to quickly move my foot to the accelerator and mash it down hard to keep from rolling back. I would be really disappointed if Toyota removes the feature simply because they think people can't handle it. RTFM people!
  9. Harold Bien
    Harold Bien Member
    113
    39
    Stony Brook, NY
    How many of these "problems" that are posted can be found simply in the manual?
    But perhaps a better option would be to disable these features by default, and require the owner to request activation via dealer or do some car dance to activate. This way, only those who read the manual will have it.
  10. Prius407
    Prius407 New Member
    My slip indicator has shown itself twice upon startup. There was no blinking or chimes and it turned off as I back out of my garage.
  11. Blackwlf
    Blackwlf Junior Member
    22
    Weare, NH
    The slip indicator will come on if the brake is pressed too hard while at stop. I have played with this a bit, and it seems mostly to be an indicator of having floored the break.
  12. qbee42
    qbee42 My other car is a boat
    18,058
    3,081
    Northern Michigan
    "Brake", not "break". The slip indicator is showing activation of hill start assist.
    Tom
  13. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    As Tom mentioned, you're activating the hill start assist. Read about it in your manual, it's described in there. It keeps the car from rolling backwards while stopped on a hill and you take your foot off the brake to give it gas.
  14. tomlouie
    tomlouie Member
    118
    Boston, MA, USA
    2023 Prius
    LOL! Like some sort of secret key sequence to access super bonus extra feature!!! "Dude, I just leveled up and got more features!!!"
  15. hoferchr
    hoferchr Junior Member
    72
    Wisconsin
    This happened to me twice today on the way to work. Roads are completely flat (city driving), and it is winter out...but no ice on the roads. Came to a complete stop at two separate red lights and had the slip indicator light flash at me. Wasn't sure what was going on...but then when I got to the parking lot at work, I pushed the brake pedal down farther, and sure enough...the light came on again. I've got a 2011 Prius w/ navigation. I looked in the manual (p. 254), and it says the Enhanced VSC/TRAC has been engaged. I just lightly tapped on the gas to get my car rolling again. Whew! I thought something was going haywire!
  16. Tideland Prius
    16,670
    That's the hill-start assist that you engaged (not the TRAC/VSC).
    If you press the brake all the way down, past a little "click", the slip indicator will flash and is accompanied by a beep. When you release the pedal, you have a few seconds to move your feet to the accelerator before the car releases the brakes.
