Slip indicator light when braking
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by raspy, May 4, 2017.
  1. raspy
    raspy Senior Member
    438
    699
    London, UK
    For a few months now, my Gen 4 occasionally is a bit jerky from the rear of the car when braking to a full stop. I notice it once or twice a week. I just noticed that the "slip indicator light" flashes whilst this jerky braking happens. On dry roads.
    This means the traction control or ABS is being invoked. It's not harsh braking as I try to brake gently. The tyres only have 7k miles.
    Is this a fault or just the way the Gen 4 drives that it can lose traction on a dry road during gentle braking?
  2. Prodigyplace
    12,692
    11,837
    Central Virginia
    I have over 6K miles on my 2017 and I have not seen this issue.
  3. fuzzy1
    10,603
    By any chance Is this happening on smooth metal covers or plates, or is it on asphalt / tar / concrete? Loss of traction on smooth metal has been known to do this on previous cars.
    Is it happening on smooth roads, or on rough surfaces, broken pavement, bumps, or potholes? In previous generations, hitting bumps or potholes has been known to trigger ABS and cancel regeneration, but with a momentary delay that creates a disconcerting 'surge' feeling. This fits with your gentle braking scenario, but is not consistent with the jerkiness or rear end feelings you mention.
    I've experience rear end jerkiness on a previous car when a brake shoe wore down and suddenly hit the rivets. But that is not consistent with your rear disc brakes or young car.
    kithmo and raspy like this.
  4. Gen 2 Tom
    Gen 2 Tom Active Member
    333
    286
    Lincoln Park NJ
    I was real big thing in my gen 2. The Gen 4 is much better. It is a wheel not going the same speed as the other wheels. Caused by hitting a bump while braking
    raspy likes this.
  5. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    I noticed it a few times earlier on but only with fairly hard braking, mostly on wet roads, and I assumed it was a "too anxious" ABS kicking in, and tyres which are ECO, not "MaxGrip". Never noticed the light though.
    raspy likes this.
  6. raspy
    raspy Senior Member
    438
    699
    London, UK
    Come to think of it, it's more like a surge than a jerkiness feeling. It could well be smooth metal manhole covers. I shall have to pay more attention to the road surface when it happens next time. The odd thing is that these are roads I've driven on with several other cars and never had the same issue, unless the Gen 4 is more sensitive than most?
    RCO and fuzzy1 like this.
  7. fuzzy1
    10,603
    Have you driven these roads in Prius specifically?
    Prius needs to have both front wheels getting smooth traction in order use regenerative braking. This is 2-wheel-only braking. If either one slips or is momentarily in the air (over a pothole or just past the crest of a bump), the car cannot brake properly, so must cancel regen mode and transition to 4-wheel friction-only braking. Often, this mode transition is not instantaneous or seamless, so the driver can feel it. On the 2010s and early 2011s, the pause was disconcerting enough to force a recall, which reduced but did not eliminate it.
    Lacking regeneration, non-hybrids don't have this mode transition. They are already in 4-wheel friction braking from the very start. Each wheel is independently controlled by the ABS, so loss of traction at a single wheel doesn't pause braking at the other 3.
    When you feel it again, please get back to us with more description of the particular road conditions.
    I don't recall seeing any comments about Gen4 being more sensitive than previous years, but the installed base isn't all that large yet.
    #7 fuzzy1, May 5, 2017
    RCO, bbald123 and alanclarkeau like this.
  8. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    With the Gen 3, the Plus (v wagon) and the Gen 4, I've had it happen over manhole covers and potholes filled with loose gravel, it only happens on gentle (regen) braking as the friction brakes take over on harder braking.
    RCO, raspy and fuzzy1 like this.
  9. bbald123
    bbald123 Thermodynamics Law Enforcement
    386
    275
    Harrisburg, PA
    Excellent explanation of somewhat troubling behavior I noticed in my Gen2. I knew it was sometimes discomfiting but couldn't figure out why or what exactly was happening. Thanks for this!
    raspy and RCO like this.
  10. raspy
    raspy Senior Member
    438
    699
    London, UK
    Yes these are my local routes I've driven with my Gen 4 and a host of other cars last year.
    It happened again today and for exactly the reasons you described. Approached a left turn in a 30mph zone where I have to slow gradually to around 10mph to take the sharp turn safely. As I slowed gently on the brakes and was just about to turn, the road has both potholes and manhole covers close together so it's very bumpy. So now I know it's not a fault with the car, it's just a side effect of driving a hybrid on a crappy road.
    RCO, fuzzy1 and bbald123 like this.
  11. fuzzy1
    10,603
    Do be aware that this will vary considerably among various hybrid and EV models. E.g. the first edition of the Ford Fusion Hybrid was noted as having a more seamless transition than the 2010 Prius (before the recall, I didn't see any comparison after). And different models have very different maximum regeneration levels, so their braking transition points will be quite different.
  12. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    FWIW, I used to get the same thing on my CR-V petrol auto, but haven't not noticed it yet in my Prius.
