Slip warning with spare tire
Discussion in 'Gen 2 Prius Main Forum' started by John He'd, Jan 3, 2013.
  1. John He'd
    John He'd New Member
    I had a flat today and put on the spare. Over about 15 mph I got the Slip Warning light and the system was limiting my speed. Is there a button or something to disable the system so I can drive at normal speeds? From other postings it seems not. Is there anything else I should be doing???
  2. edthefox5
    edthefox5 Senior Member
    10,096
    4,806
    Clearwater, Florida
    Nope no button. Very aggressive anti skid system. Toyota got a little carried away. Get that tire off asap.
  3. Patrick Wong
    18,200
    6,479
    1) Inflate the spare tire to 60 psi.
    2) If that doesn't help, move the spare tire to a rear position.
    PriusCamper likes this.
  4. John He'd
    Tire fixed. Thanks for info.
  5. John He'd
    Interesting. So u think the stab control only uses front tires? If so they should advise this in the manual.
  6. PriusCamper
    PriusCamper Senior Member
    11,160
    4,544
    Pacific Northwest, USA
    Yea... the traction control is primarily about protecting the hybrid drive train instead of actually getting better traction. If I ever get a flat front tire... I'll for sure never put the spare on the front because of possible damage / same damage that the traction control is trying to protect the car from.
  7. PriusGuy32
    1,417
    512
    Harrison Township, Michigan
    Good to know. And while we are on the topic, really Toyota, really? Did you have to paint the spare tire such a "stick out like a sore thumb" color?!? It already looks like a 10-speed bicycle wheel, there really is no need to draw any more attention to it :rolleyes:
    uart and PriusCamper like this.
  8. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    It might be by design.
    I can't find the post but I thought RonDawg on Tivocommunity (he's a cop) posted about them intentionally being a weird color for safety reasons, so that people know you're running on a donut and your speed is limited.
  9. cwerdna
    12,544
    2,123
    SF Bay Area, CA
    After some digging, I found his post. Here's an excerpt:
  10. uart
    uart Senior Member
    4,215
    1,201
    Australia
    Funny. The first time I saw the Prius spare I started looking all around for the rest of the wheel barrow. :D
    PriusCamper and PriusGuy32 like this.
  11. dorunron
    dorunron Senior Member
    3,318
    1,103
    Houston, TX
    One other fact that has not been mentioned, the Prius spare is not designed properly for the lug nuts on the Prius. Look closely at the donut spare and you will see that the holes where the studs go thru the wheel are tapered to fit a "standard" lug nut, and not flat like the standard wheel. IMO, the Prius spare is not really safe to use because the lug nuts could possibly work lose. You can buy standard lug nuts for the spare, but that is bordering on insanity. I understand why the color is awkward, off etc but I don't appreciate the difference in the design where the lug nuts come into play when using the donut spare.
  12. PriusCamper
    11,160
    4,544
    Has anyone bought a full size spare so they don't have to worry about being crippled by a fake wheel? My last car (Subaru) came with a donut but the spare tire location could hold a full size tire. I doubt that'd work in a Prius, but I'm gonna look into seeing if a mod could be done to make it fit somewhere.... I sure wish lots of flat tires to the Toyota designers that think donuts wheels or worse a can of fix-a-flat is a legit solution for Prius users.
