Slips and tire chirps accelerating on right turns
Discussion in 'Toyota Prius Service Bulletins - TSBs' started by Billdig, May 13, 2010.
  1. Billdig
    Billdig Junior Member
    Colorado
    My 2004 just started something I can't figure out. From a stop, making a right turn, accelerating normally, it hesitates/slips? and sometimes the tire chirps. And of course, it does not happen every time, road conditions vary, no clear connection to anything else. And the "Maintenance Required" light just came on, but the slipping has been happening for a month or more. Only 32,000 miles, got a steal from my father-in-law, but I've only had it 3 months.
    Thanks in advance, I've already found other answers on this forum that have helped a bunch.
    Billdig :confused:
    ______________
    2002 Prius
    (that would be two "Prii" right?!)
  2. vertex
    vertex Active Member
    672
    144
    new york
    2018 Prius Prime
    The maintenance lilght just means that you may need to change the oil.
    Do you have the OEM tires? You probably need new tires, the OEM ones don't have good traction, and can cause this problem as they wear out.
  3. hobbit
    hobbit Senior Member
    4,089
    469
    Bahstahn
    geez, try taking it a little easier.
    _H*
  4. Billdig
    Colorado
    Actually, I'm in Colorado and have not changed out the winter tires. Should have by now, but it did snow just last week. I'll wait until I change back the the all season radials before assessing if there's a problem.
