Sloshing sound...Prius 2006. Conducted research but no solution
Discussion in 'Gen 2 Prius Main Forum' started by Blegate, Oct 3, 2012.
  1. Blegate
    Blegate Prius Gen III 2013
    132
    Vancouver, WA
    Hello, I've got a 2006 with about 108k on it. I've noticed in the last month (or two) an odd sloshing of water that occurs BEHIND THE DASH when the car is first turned on and then appears to go away when warmed up. About a mile from my house this morning, I noticed the sound again when taking a right turn at a stop sign. This concerns me.
    Here's what I've done:
    1) Fluids are fine in the car. Checked them nothing low
    2) no codes have been logged in my car.
    3) I've researched this site and thought clogged evaporator ac drain tube so I tried clearing it. I fired up the compressor, got underneath the car and proceeded to blast small shots of air up the tube. Nothing happened. No water coming out. Btw, there has not been any water drainage inside the car on either the driver or passenger side.
    I'm at a lost here which I hate saying. It's hard to replicate once the car is warmed up.
    Should I be concerned? Car runs fine. Mileage is great. Ac is perfectly cold. Heater gets hot.
    Brian
  2. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    Unfortunately, further "research" or investigation is your only avenue.
    I've owned cars/trucks where drain plugs...usually located in the bottom of the doors have plugged up and I started hearing "sloshing"....but once it started it was constant, in other words did not go away with driving...and it certainly wasn't behind the dash.
    I'd be "concerned" but not alarmed. If you can get it to replicate, the quickest avenue to discovery might be a drive to a service center.
    But "sloshing" that appears-then disappears has me stumped.
    Once you track it down...let us know what it was.
  3. nh7o
    nh7o Off grid since 1980
    1,686
    340
    Hawaii
    It is probably the rain gutter which runs under the windscreen. It has an outlet on one side only, and as I read it gets clogged with leaves, etc. such that one hears the sloshing that you describe when turning. Open the hood and remove the plastic cover with the grating to get at it.
  4. Patrick Wong
    18,210
    6,526
    I agree that the cowl tray that houses the windshield wiper motor is the likely source of the sloshing sound due to trapped water. There are two drains: one on each end of the tray.
    It is necessary to unbolt and remove the windshield wiper arms first. Then two plastic fasteners on the ends of the black plastic cover can be removed and the two cover pieces can be lifted out.
  5. PriusDIY
    PriusDIY Junior Member
    49
    Minneapolis, MN
  6. Blegate
    132
    Vancouver, WA
    Thanks for your replies. Been busy. Big thanks to Priusdiy for the article. I need to change out the pcv and the plugs. The directions are perfect. Im planning on doing this tomorrow. Thanks. Brian
  7. Joe 26
    Joe 26 Member
    242
    42
    Columbus, Ohio
    Have you had any recent repairs?
  8. Glen
    Glen New Member
    You should be checking coolant level and check it cold at the radiator cap. When the cooland is low and the engine first starts you hear coolant and air circulate through the heater core. I have had this on other vehicles.
  9. Joe 26
    Joe 26 Member
    242
    42
    Columbus, Ohio
    What Glen wrote was what I was trying to get at. It is particularly difficult to get all the air out of the cooling system on the Prius when repairs are done to it; it only needs to be down a little to give you that "sloshing" sound, from air in the heater core.
    Try running down the highway with the heater on econ and full hot for a period of time and then re-check the level in the bottle.
  10. Peter Fanelli
    Peter Fanelli Junior Member
    36
    Smyrna, Tennessee
    I bought my first Prius a few weeks ago and have noticed the same thing on a couple of occasions. In my case it has only happened after the car has been standing in rain so I'm certain the problem is not engine or cooling system related. I'm sure it's water in that area down below the windshield. You'll probably notice that like mine if you weave as you go down the street that it will dump the water out on the road after a couple of weaves and the problem will go away until next time it rains. I figured it was a blockage up there somewhere, guess I'll do some poking around this weekend and see if there's a blockage.
